Page 1 of 3 123 LastLast
Results 1 to 15 of 42
Thread: High 13s
    Jan 2016
    South NJ
    High 13s
    2003 marauder. Completely stock. Just bought a k&n fipk and a 93 octane tune from MO'S. I am looking to keep stock gears and go 13.90s. in the future I will be getting a 2.5 inch x pipe and high flow cats to replace the stock setup.
    Tell me what it took for you to go 13.90s at sea level.
    I went 13.72 with JLT intake, PHP intake spacer, 93 octane tune, 180 degree t-stat, NGK TR6IX plugs, GMS coil connectors, PI 3500 stall converter, deleted rear cats, flowmaster super 40 mufflers, stock gears and 255/50-16 drag radials. Ran a little less than half a tank of gas, pulled the spare out and pulled driver side headlight out. Track was 20 ft above sea level.
    Before going 13.7x, my fastest was 14.35. Added the 3500 stall converter, drag radials and a tune from Zack is what helped drop more than half a second.
    Video is of my 13.74 run. Later that day I ran 13.72.
    After having my exhaust complete re-done from stock manifolds back, 4.10 gears, UDPs and dyno tune I went 13.63. Trans parameters were off in the tune and had converter issues. 150k on the motor as well.
    Add 4.10 gears, 3000-3200 stall converter and you'll be there. Could also ask MartyO aka Mo what he would recommend as well. You'd need a 4.10 gear tune and adjustment for the higher stall converter also to take advantage of their benefit. Each car can react differently to mods, but most see around the same results.
    300B
    Exhaust by Greg
    2015 Ford Focus SE Sport FWD
    2010 Ford Fusion Sport FWD
    Jan 2016
    South NJ
    Thanks. Not going to do a converter or gears though.
    Apr 2006
    Smyrna, DE
    gears + headers + tune and then ------maybe.
    3.35 L 4X4
    -AND-
    SLAYER1
    Nov 2013
    CT, MA
    Quote Originally Posted by 376shovel View Post
    this will create a serious challenge toward reaching your goal.
    2004 SILVER BIRCH/BLACK PAINT
    DARK CHARCOAL NUDO LEATHER
    #400 of 997 (SOLD)
    2004 CV LX SPORT
    2004 300A MM BLACK
    1 OWNER CAR, NO OPTIONS
    DAILY DRIVER
    2013 DAYTONA R/T
    SUPER TRACK PACK
    DAYTONA BLUE PEARL
    #1763 off ~2100
    NOW WITH A 392 & 3.73 posi!
    Apr 2006
    Smyrna, DE
    then eaton swap........
    3.35 L 4X4
    -AND-
    SLAYER1
    Jan 2016
    South NJ
    I guess I'll have to run it go see where I'm at. This is my new daily driver. I have another car I use to race. I just wanted to know if anyone has done it with 3.55s on here yet
    Blog Entries
    2
    Nitrous...................
    Apr 2010
    South Florida
    I have JLT intake, rear cat delete with MagnaFlow Mufflers, NGK TR6 Plugs and Marty 93 Tune and ran a 14.58 on factory wheels n tires. Next mods will be 4.10 gears and SW Headers. Hope to reach 13.90's. If not then 75shot to get Me in 13s.
    #1618 of 3214
    Jan 2016
    South NJ
    #1618 of 3214
    Did you do runs before and after those changes? If so what results did u have?
    Apr 2010
    South Florida
    No, I never ran it when the car was factory but I heard they run anywhere from 15.3-15.5 stock if I'm not correct?
    #1618 of 3214
    My DTR runs mid 16's with mods, we tried to do a video, but the camera operator fell asleep just waiting for the burnout to happen.
    Trilogy # 192 / T.S. 0012
    Rockford
    That low 14 high 13's appears to be the threshold for our cars n/a.
    This is subject to lots of variables, so you "see level" guys , take it easy! Lol
    I never got into the 13's without FI, the best was 14.2@97.XX
    Sent from my XT1096 using Tapatalk
    Jan 2016
    South NJ
    Quote Originally Posted by Bradley G View Post
    Thanks for the info. What was done to your car when u ran that ET?
    Blog Entries
    2
    Chip, 4:10 Gears, Under Drive Pullies – 14.274 @ 97.05 MPH
    +PI Torque Convertor – 13.74 @ 98.33
    Temp/Humidity can add .75 to your best time.
  1. High Flo
    By Timw286 in forum Exhaust
    Last Post: 06-22-2011, 12:13 PM
  2. Why is my car still in the high 12's???
    By justbob in forum Drag Racing Round-up
    Last Post: 05-20-2010, 09:19 AM
  3. I like them, but they sit too high
    By Egon Spengler in forum Shop Talk
    Last Post: 08-29-2008, 07:15 PM
  4. High RPM Fix?
    By Ross in forum Shop Talk
    Last Post: 11-05-2003, 02:04 PM
  5. High Speed High Frequency Noise
    By engine23ccvfd in forum Community Discussion
    Last Post: 07-25-2003, 10:06 AM
