Results 1 to 15 of 16
Thread: Drag Shocks
    Warson Woods, Missouri
    Drag Shocks
    What has been your experience with finding the best drag shock set-up for the Marauder? Do you use 50-50 rears and 90-10 on the front? Is a specific brand preferred? Are there other things to pair with shocks to lower 60 foot times: rear control arms, no front anti-sway bar, etc? I can't get below 1.87 or so, using MT strip drag radials, 3.7 gears and 484 RWHP.
    Blog Entries
    2
    1.667 - see my sig. Please post your time slip data and the specifics on your mods.
    Are you spinning out?
    Apr 2006
    Smyrna, DE
    What he said....
    3.35 L 4X4
    -AND-
    SLAYER1
    You have been pumping money into this car for years, and have yet to get a timeslip that reflects your mods.
    You don't need drag shocks or any other fancy expensive part to get a good 60'. (rear CA's don't hurt though)
    Just good tires and a driver mod.
    60 foot
    You are right about the driver mod. My son is always faster than me, same car, same night. But since I like to drive it, my two runs (11.91 and 11.92 at 117) are my best. Traction now with MT drag radials is better. With good burn out (line lock) I now stick the tires with no spin.
    I have Monroe shocks, 3.7 gears, 484 rwhp, strengthened Trans w/ forced tail shaft lube, Addco rear (and front) sway bar. Tommy control arms and Watts link. I will have time slips this coming Friday at the Midnite Madness runs at Gateway MSP. That should confirm traction, and consistency.
    My son thinks I now need to up the power. You had noted earlier that Lidio may have backed off the timing some to keep user error from blowing up the engine. Might be time for a re-tune.
    Yes on spinning out, but with new MT drag radials, current runs have limited-to-no slip. Representative Time Slips, all on 93 Octane:
    04/7/12 1.979 12.192 116.19 Nitto
    11/9/13 1.840 11.927 117.25 Nitto
    11/8/14 2.009 12.245 114.77 Nitto
    8/22/15 1.786 12.156 113.61 MT
    10/3/15 1.751 11.916 114.57 MT
    04/1/16 1.886 12.171 114.35 MT
    Mods include: Kooks, 2 1/2" all the way back, built trans, 31 spline, Eaton LSD, 3.7 gears, 60# injectors, stock fuel lines, Ford GT pump, Boost-a-Pump, Ported Trilogy w/ 3.6 upper, SCT Big Air 2800, stroker, forged internals, 10.25:1 CR, widened OEM rear wheels.
    Dyno 10/19/13 481.02 HP 431.75 torque Mustang Muscle, St Louis
    09/03/11 487.0 493.6 Alternative Auto, Detroit
    Winnipeg,Mb.
    How are you launching off the line? Are you pre-loading the converter or hitting from idle? When I was drag racing I would preload to ~1800rpm (can't remember exactly, it's written on my slips somewhere). I was consistently in the 1.7xx for 60ft. unless I blew the tires off.
    -Mike
    #6018 of 11,052
    Trilogy #196 - Self-installed
    Stuff done to it. See here.
    May 2003
    Waterloo, IA
    What converter are you running?
    Nov 2010
    schenectady
    for a better 60' you need to change the gears to 4:11 ,4:30,or 4:56.
    Sep 2006
    Psych ward
    Quote Originally Posted by Triple Threat View Post
    horse power wouldn't hurt either....
    • 82 GT coyote swap started
    Quote Originally Posted by Sully008 View Post
    I pre-load, but more like 1200 to 1500
    Quote Originally Posted by TooManyFords View Post
    OEM Ford TC with 12k miles on it.
    I will check trap RPMs Friday night, to see if I have room for more gear
    Blog Entries
    2
    Quote Originally Posted by BUCKWHEAT View Post
    I am not aware of anyone with 4:10's running out of RPM's.
    09-27-2003, 08:49 PM
    Lidio Lidio is offline
    Supporting Vendor
    Trader: (0)
    Post Feedback
    Thumbs up Trilogy car goes 12.69 in Bowlinggreen, KY
    Just wanted to give yet another awesome update on the Trilogy number-1 car. Jerry has it in Bowling Green, Kentucky for the NMRA race at Beechbend raceway.
    As predicted with the slightly cooler air…. About mid 70 degree temps. The car blasted a 12.69 @ 108.6!! This is with only a 1.94 sixty foot.
    In TX it sixty footed in the 1.87 range which is very good for a car of that nature on street tires. With 50-60 degree temps and the 60 foots where they should be, I feel that 12.50’s later this fall are totally with in reach. This is all being accomplished with a guy who’s only been down the drag strip two or three times before! Just a simple burn out and then floor it with the shifter in drive when the lights come down.
    Quick recap on the car:
    -Trilogy blower making about 11.8psi
    -4.10 gears
    -Nitto 305-45-18’s on widened 18X9.5 wheels
    -FlowMaster 50 series delta-flow mufflers
    -custom 2 ¼ x-pipe from the stock four cats back to the mufflers, all other
    exhaust including manifolds, cats and tails are stock
    The trans and torque converter are stock and the vehicle weight is stock except the jack and spare are pulled for drag racing.
    Thanks
    With my Trilogy I went from high 12.4's to consistent low 12.1's overnight by no longer loading it up to just stabbing it right off idle. Every car is different.
  1. For Sale Custom Drag Wheels with BF Goodrich T/A Drag Radials
    By jspradii in forum Marauder-specific Parts for Sale
    Last Post: 10-19-2012, 10:18 AM
  2. Shocks?
    By blackhueys in forum Steering, Suspension & Brakes
    Last Post: 12-17-2009, 06:47 PM
  3. Old or New Rear Shocks for Drag Racing
    By Glenn in forum Drag Racing Round-up
    Last Post: 10-18-2008, 04:07 PM
  4. Need shocks for my 99 P-71
    By 99-P71 in forum Shop Talk
    Last Post: 05-17-2007, 07:07 AM
  5. SSM Drag Night - Bradenton Drag Strip
    By MarauderTJA in forum Sunshine State Marauders
    Last Post: 04-06-2007, 07:57 AM
