Results 1 to 15 of 22
Thread: Just got myself an MM! What fuel to use?
    Nov 2016
    Vancouver, BC
    Hi all, just got myself a 300eh Marauder, upgraded from a CVPI. I'm absolutely loving it. Thanks to other members for posting on this site; it really helped with my decision to upgrade. Except now I have to fill up the tank...
    I know premium is required. But what exactly does that mean? In my area we get 87, 89, 91, and occasionally 94. Which is the ideal grade to use? Also, is it an option to buy cheap 87 gas and use an octane booster such as STP?
    I don't mind paying extra for better quality, but if there are cheaper/easier options that achieve similar results I'd really appreciate that.
    Thanks in advance!
    Last edited by badgrandpa; 11-06-2016 at 01:11 AM. Reason: Forgot to say thank you
    Oct 2003
    Beaufort, SC
    WELCOME ABOARD!!
    91 is fine and you might try 94 later to see if it's any better but probably not!!
    These cars with OEM tunes will run on 87 but timing will be pulled by the PCM and performance will suffer!!
    Glad ya finally got one and hope you enjoy it as much as I have....I'll have had mine 13 years on 11-25-16!!!
    WELCOME ABOARD!!
    Uh what?????????
    Oct 2003
    Beaufort, SC
    Yep!!
    Dom ran his on Kerosene....remember!!
    We ran the wife's on regular for a year or so. it developed a slight rattle at startup and throttle tip-in. Switched to premium and it didn't fix it. Had the Ford dealer de-carbonize it. I believe they used something from B-G. It cleared up the rattle. Stayed with premium after that and the problem never returned. We use whatever brand is the cheapest, but it is usually 93 octane. Now it has 276k.
    Oct 2003
    Beaufort, SC
    The owner's manual recommends 91 octane and states that using fuel with less octane MAY effect performance!!
    Apr 2016
    fergus falls mn
    Does anyone use injector cleaner and if you do what kind
    Sent from my SAMSUNG-SM-J320AZ using Tapatalk
    Quote Originally Posted by badass mm View Post
    Never used it on my Marauder, but I've used it on other cars..It used to be a dealer only item, now can buy online amazon etc.
    https://www.bgprod.com/catalog/gasol...ystem-cleaner/
    Apr 2016
    fergus falls mn
    So do you recommend not putting it in at all
    my marauder doesn't see much mileage last couple years..so I haven't used it in it, but I will prolly in spring as it is pretty much ready for winter..just put a can in my truck in spring and daily driver this last weekend.
    Apr 2016
    fergus falls mn
    Okay sounds good thanks Rubber City rauder
    Bergen County, NJ
    The car runs best on the recommended 91 octane. I don't use injector cleaner as that grade of fuel already has cleaners in it. I do use fuel treatment for the winter storage. If you don't, the gasoline will form chunks in the tank and fuel lines if storing for a great length of time.
    Put it in the tank, run the car, run the car a few laps around the block, and put it away with the battery tender.
    In the spring, she is ready to go.
    Jul 2014
    NY
    Congratulations and Welcome! Yes, the MM requires premium. The 2003 Marauder Owner's Manual (p. 197) recommends 91 octane or higher. I personally use 93 or 94 octane at all times. I have had panthers for twenty years at this point including CVs, MGMs and now Marauders and I have always used premium on all of them (even though the CVs and MGMs does not require it). There were times in college where I skipped a few meals, so that the car could have higher quality octane to prevent future problems.
    Do yourself a favor, always use 91 octane or higher. The MM is a special limited-production vehicle. They only made about 11,000 of them. Using lower octane can lead to knocking and other issues, especially during the winter months. Using 91 or higher octane will prevent future problems, less headaches and less repairs. So what you "save" on lower octane gas now, you'll pay for much more later with car parts, time and labor repair expenses.
    For fuel injector cleaners, I use Chevron Techron Complete Fuel System Cleaner 20 oz every 3,000 miles.
    http://shop.advanceautoparts.com/p/c...5740/7080568-P
    If you are interested in knowing more about your MM, here's a great website with some links for you to read up on your new car:
    http://gdmjoe.com/marauder/documents/documents.html
    Quote Originally Posted by badgrandpa View Post
    Thanks in advance!
    Store shelf octane boosters are a joke, the only one I've used is torco and it's expensive
    You don't need a octane booster, you just need premium fuel with clean injectors
    My DD 300'eh would ping with 4 fat guys in it, I put one bottle of injector cleaner in every 3rd tank full My black has 206k on it and no more detonation
    I just buy the cheap injector cleaner at Walmart 98 cents per bottle
    Congrats on the purchase, they are great cars
    north nj (Planet Houston)
    And if you get a super charger it bumps up to 93!
  1. Single GT-40 fuel pump install
    By juno in forum Shop Talk
    Last Post: 08-19-2009, 10:27 PM
  2. Fuel System Upgrade
    By FordNut in forum Shop Talk
    Last Post: 12-19-2007, 02:34 AM
  3. Please don't yell at me....
    By natedog1284 in forum Shop Talk
    Last Post: 05-01-2006, 07:46 AM
  4. This may not be popular(concerns fuel flow)
    Last Post: 01-22-2006, 04:15 AM
  5. MPG Increases, Saw it on another Site.
    By gray bear in forum The Lounge
    Last Post: 08-24-2005, 12:36 PM
