Originally Posted by
HorneDogg
its a MMR 1000SE short block, yes I understand that they should be able to find out what is going on.
The tune was originally a Reinshart tune as you say. I only have 30k .... and the original engine went to crap.
Nothing surprising there!
Sorry for the thread Hi-jack....hope that they figure out WTF is going on.
