Results 1 to 15 of 17
Thread: Hood Liner Protection
    Dec 2016
    Cincinnati ohio
    Got stuck having to drive my '03 on the salty Ohio roads last week so I ran it through a car wash to get the underbody rinsed. Noticed that the hood liner got very wet and I realize that is not good for it in the long run. Anybody ever cover it with clear plastic or find some other way to keep it dry in this situation? What about spraying it with water repellant fabric protector? With only 10,000 miles, I want to try and protect as much as I can (without locking it in the garage and never driving it)
    Just buy another one and keep it for a spare
    Dec 2009
    It's made of fiberglass. Water won't hurt it. I spray mine off and douse it with armour all or whatever after it dries. Always looks nice.
    Dec 2016
    Cincinnati ohio
    Mine is not fiberglass, it's a fabric of some sort, pretty much like every other liner I've seen. Has 'Marauder' embroidered on it.
    take it off in winter
    or try scotchguard
    Quote Originally Posted by Rlutterb View Post
    Oh you have one from CAR Motorsports.
    Dec 2016
    Cincinnati ohio
    I thought about removing it but those plastic plug/clips really don't like being removed and replaced very much.
    I thought my car was mostly 'stock' but I continue to learn that there were changes made. So a cloth one with a sorta faux embroidered 'marauder' is aftermarket? The trunk liner is the same material. Wish I could make it to the Louisville meetup to get some experts to tell me what's been modded but I cannot take off during the week to make it.
    May 2011
    Schenectady, NY
    Buy a box of the plastic clips at any parts store.
    300A Black
    Nov 2012
    Sacramento
    Quote Originally Posted by camelgrundle View Post
    This they arnt expensive!
    There are at least two manufacturers of the stock unit. I ordered two and received two differently made, each madewith two different materials!
    One was really cheap and shoddy and already separating, and the other looked more stock like ours. Had to fight with Ford to get my money back for the cheaply made one.
    It really helped the open hood look of the car. Amazing difference. I think a battery or hose or something had "sploaded" under the hood at some point. Everything else perfect, now hood liner is too.
    If there is one in the trunk, it is for sure aftermarket. Our trunk lids were nekkid from the factory.
    There used to be another company in addition to CAR motorsports which made them, I don't think they're in business any more.
    My trunk liner came from DecklidDesigns years ago when they were a supporting vendor on the site. I won it in the raffle at MV III in Detroit, MI back in August 2005.
    Got my plastic push pins at Lowe's Hardware for about 1/10 of what Ford Parts wanted for them.
    Dec 2016
    Cincinnati ohio
    I'm used to restoring vintage VW's where having the factory correct push pin is preferred. Those are not available at a local FLAPS, so I never thought about just removing it and buying new pushpins for the more modern MM where the liner isn't factory and originality is already moot. That's the route I'll take!
    Ford has the push pins
    GM ones are better, xmas tree type versus the Ford style
    http://www.clipsandfasteners.com/Hoo...M_p/a11130.htm
  1. Any reason why no hood liner?
    By BigGuyBigCar in forum Shop Talk
    Last Post: 03-08-2006, 05:25 PM
  2. New hood liner installed
    By Hack Goby in forum Shop Talk
    Last Post: 09-12-2005, 06:26 PM
  3. RAI edge contacting hood liner?
    By Svashtar in forum JLT Performance
    Last Post: 06-10-2005, 05:56 PM
  4. Hood Liner Cut-Out
    By Smokie in forum Shop Talk
    Last Post: 06-04-2005, 05:32 AM
  5. Hood Liner
    By martyo in forum Shop Talk
    Last Post: 10-20-2004, 11:12 AM
