Page 1 of 3 123 LastLast
Results 1 to 15 of 40
Thread: Granatelli Coil Connector Install *DUW*
    Derby City, KY
    OK, I had to try this myself and share with the group as it is honestly quite a simple install/upgrade.
    Make sure and remove the coil cover in such a fashion that will not damage the gasket on the cover, or displace it.
    Carefully lift one of the coil/boot assemblies from the spark plug cavity paying attention not to pull anymore than necessary on the wiring harness. (I used my other hand to bend the rubber boot when removing from the spark plug cavity, making it a little easier).
    Seperate the wiring harness by pressing on the top tab while pulling the two halves away from one another.
    Remove the rubber boot from the coil pack by rolling the rubber down and away from the coil pack. This was the hardest part and took the longest. While the rubber was rolled away from the coil pack, use a twisting motion back and forth while pulling, and it should finally break free, exposing the OEM spring.
    Carefully twist and pull the spring closest to the coil pack until it comes free. (The spring will more than likely bend upon removal as they are very weak). You will then be able to see the 'tab' that holds the connector in place.
    Place the Granatelli connector over the 'tab' and press on. (This is a tight fit. Make sure it is on all the way seated).
    Slide the boot over the connector ensuring the coil pack and the boot mate together as shown:
    Replace the wiring harness back onto the coil pack making sure it is fully seated. (You should hear a 'click' when seated correctly).
    Carefull locate the boot end into the spark plug cavity until you feel it touch the end of the spark plug. Now, I had to press using quite a bit of pressure until I heard the connector 'snap' onto the spark plug. (I made sure my thumb was centered on the coil pack and placed my other thumb over top using both hands to press).
    It appears the Granatelli connectors are shorter than the OEM. Once installed, the coil packs do not seem to stick up as far as with the OEM connectors.
    Inspect the coil cover gasket ensuring it is fully in place on the coil cover before replacing onto the cam covers.
    It may be a good idea to ensure the bolt holes of the coil covers line up with the cam cover bolt holes before resting in place. (Worked for me).
    Tighten coil covers appropriately.
    I truly hope this helps everyone that has either purchased these connectors, or are thinking about purchasing them. Previous installs may have received some negative feedback. But I can assure you, this is quite simple for anyone to do themselves.
    Best,
    Mike.
    MikesMerc Guest
    Great post! I hope to get my Granatelli Coil Connectors on this weekend. Thanks for the install tips and pics
    Cape Cod
    Great pics, nice and simple instructions! Thanks, Mike! Another great addition to the Reviews section too!
    MOK
    I don't brake for curves!
    Derby City, KY
    Thanks Mary and Mike!
    I have to thank Mac for making himself available while doing this. I did have a couple of questions, and his experience helped me along.
    Mike.
    May 2004
    Venice, Florida
    All my questions about this mod are now clearly answered. Great Job, Mike!!!
    2003 Marauder 300A
    Tallboy's Garage
    Off-Shore America
    Nice job, Mike! Great pics too.
    Aug 2005
    Macclenny, Florida
    Mike, your pictures pointed out how much more substantial the replacements are over oem.
    I feel better just knowing the "ball point pen springs" are no longer a vital link to my spark plugs!
    Did mine during the last group buy, about 5k miles ago, and highly recommend this mod.
    It truly is a no-brainer!
    ~Jim
    2004 Mercury Marauder SB
    Jan 2006
    Central Ohio
    Nice write up Mike! Glad to see it isn't that difficult. Perhaps this weekend ???
    KillJoy
    Derby City, KY
    Quote Originally Posted by KillJoy
    KillJoy
    Thanks Steve. If you have any questions, call my cell: 502.558.2912.
    Mike.
    Cape Cod
    MOK
    Aug 2005
    Macclenny, Florida
    Quote Originally Posted by MM03MOK
    Wow Mike!
    You've been Published!
    ~Jim
    Port Charlotte, FL
    Cool! I got mine yesterday. They went into the pile o' stuff waiting to get put in when #132 arrives. This is a great help!!!
    04 Crown Victoria Sport
    1995 F150 4x2 4.9 5spd
    Seeing as so many of you are doing this, that leaves 8 OEM coil springs for each person. How about mailing them to me? It could help in my troubleshooting. Please, only non-damaged ones...PM for address... thanks to those that are helping me out. I need to drive my Marauder, I'm going through withdrawl...
    Derby City, KY
    A few more details:
    I did not use the dielectric grease. I was pleased to not see any evidence of moisture and simply did not see the need.
    The rubber ring on the Granatelli connector was left near the center prior to installing the boot.
    Removing the OEM connector from the spark plug has little to no resistance due to loose fit. You WILL know when the Granatelli connectors are seated onto the plugs. Major difference over the OEM as the pics show.
    I will give a comparison on driving/SOP when the weather is good and I can wash the MM. I will not drive her in the rain nor when dirty.
    The engine bay could use a good wash too.
    Mike.
    Quote Originally Posted by MM2004
    A few more details:
    Mike.
    Rubber ring?? What rubber ring??
  1. Granatelli Coil on Plug Connector Kit Group Buy #2
    By maraudernkc in forum Forced Induction Technologies
    Last Post: 06-30-2006, 01:03 PM
  2. Granatelli Coil on Plug Connector Kit Group Buy
    Last Post: 06-12-2006, 09:38 AM
  3. Granatelli COP coil upgrade -quantitative results?
    By metroplex in forum Shop Talk
    Last Post: 01-18-2006, 01:54 PM
  4. Coil on Plug for 4.6 32V
    By maraudernkc in forum Community Discussion
    Last Post: 11-12-2004, 03:49 AM
  5. Easy way to shorten front coil spring
    By Thomas C Potter in forum Shop Talk
    Last Post: 02-29-2004, 03:29 AM
