This is an e-mail update from VT Engines on my car.
We have the engine completely disassembled right now. I waited to give you
an update because after we pulled the heads off, it looked like the mains
could be bad. Fortunately, it did not spin the bearings, so the block was
ok.
I included a couple of pictures for you to see the failure on the pump gear,
and to see the inside of your engine.
Your engine is coming along well, my builders are balancing your rotating
assembly right now.
Talk to you again soon,
Tom
