Results 1 to 8 of 8
Thread: Headlight Problems
    Aug 2006
    Alabama
    Headlight Problems
    Hey guys, I've been having these headlight problems with my 99 crown vic p71. I've been trying to put blue bulbs in my car but everytime I do they cause my headlights to start flashing on and off. So I end up having to change the headlight switch which correct the problems. The blue bulbs I tried are rated at 80/100 where as my stock bulbs are rated at 12V 65/55. Well later on I found some blue bulbs rated at 12V 65/55 same as my stock ones. I tried those and my lights still started flashing on and off. So now I have to go get another headlight switch. What am I doing wrong? Any input would be greatly appreciated.
    Lehigh Valley, PA
    could it be a faulty relay burning out your switch?
    2063/3214
    5377/7838
    Aug 2006
    Alabama
    I don't think so because I can drive all day long with my stock bulbs on and nothing happens.
    There is a breaker inside the headlamp switch or in line with the headlight wiring harness which will (when the amperage is exceeded) open and when it cools it will close again. The visual clue will be the headlights going on and off as the lighting is exceeding the maximum current value set by the breaker.
    To avoid this you must add a large relay in place of the headlights in the circuit and use the headlight line to trigger the higher current relay with its higher current source (like a direct fused connection to the battery) which will in turn supply the current to the higher amperage headlamps.
    This is a simple circuit but it will take some time running the wires to the head lamps and adding fusing and making your own harness to do such a thing. The Ford harness ratings will not allow for those massive lights so you must use the headlamp line to trigger a more heavy duty circuit for your needs. Simply bypassing the headlamp relay or bumping up the breaker size will eventually cause a failure in the harness or light the harness up like a candle. Do it the right way or leave it alone. Richy
    Purgatory, FL
    Check the lighting control module. They had a TSB for the turn signals flashing fast intermittently. But the same module could cause your problem.
    (#6178 in black per FPIC)
    Rest In Peace:
    Paula Babineau 1/9/67-8/2/11
    Rex Weinbender
    Peter
    NorthEast Kingdom of VT
    Most states require a permit for any blue light showing to the front.
    Long Island, NY
    Quote Originally Posted by cyclopsram View Post
    In New York State only volunteer firemen/women can use blue lights while respondiong to an emergency. The must obey traffic controls.
    2003 Marauder 300B,
    Heated Seats
    35% Tint
    Mercury All Weather Mats
    1973 Oldsmobile Toronado
    2012 Kia Sedona Van
    2008 Corvette Convertible
    2021 Prius Prime Limited
    Member # 440
    ----- John
    Lehigh Valley, PA
    I think he means headlight bulbs, not the siren lights
    i think?
    2063/3214
    5377/7838
  1. problems, problems, problems....
    By Advancedautosec in forum Community Discussion
    Last Post: 06-11-2007, 08:58 AM
  2. Alternator Problems
    By Badger in forum Shop Talk
    Last Post: 03-30-2006, 06:06 PM
  3. Problems! Problems! Problems!
    By Go Mifuni in forum Shop Talk
    Last Post: 11-23-2005, 12:36 PM
  4. Customer Service, Superchargers, and Problems
    Last Post: 03-12-2005, 11:03 AM
  5. Problems Fixed Mods Installed
    By JET in forum Shop Talk
    Last Post: 08-28-2004, 11:56 AM
