My car was hit in the front and needs a used mint preferably black bumper cover.Anyone know where i might find one?
Yep i have 2 and i think it would be a vary nice drive for ya...lol.......sorry not shipping
I need a cover in black in mint condition, If you have one send me a good picture and price and i will see if i can get a packing and shipping place to pick it up if its affordable. JONATHANTAYLORHART@YAHOO.COM
There are a couple of sellers of reproduction fronts on ebay, they're around $550 shipped. Then have it painted at a local body shop and swap it yourself.
I've purchased two of them from two different ebay sellers, they came from the same manufacturer so I assume they're all manufactured at the same Taiwan factory. They fit just fine, nobody has ever noticed any fit problems.
Only issue is one I discoverd after painting the first one, that there is a little bit of mold flash from the injection molding process. If you don't sand it off yourslf before taking it to the body shop they will probably just paint over it. The second one I sanded it off first and it looked perfect after painting. The problem spot is at the top rear, near the marker/signal light and fenderwell.
Are they hard plastic or flexable like oem?
Flexible.
Found an oem in black primer...
