Results 1 to 15 of 24
Thread: EATC codes 024 and 025
    Feb 2011
    New Jersey
    Ran a self test on my eatc and got codes 024 and 025.
    Problem im having is that no matter whats selected either floor, defrost or vents, heat comes out thru everywhere. another issue with this is that If I start playing with lowering the temp, a knocking noise behind the dash will start like if something is stock. It will eventually stop but it takes about 3-5 mins. when switching to A/C also does the same thing but I get my cold air. So heat and A/C are both working. Its just that its blowing thru everywhere and the knocking noise when switch the temp.
    Any Advice?
    those are blend door codes, prolly blend door actuator
    Have you replaced the silicone 007 o rings in the eatc?
    Those are the remedy for your air everywhere issue
    If you get full cold and full heat, I don't see it being the blend door actuator
    Usually the actuator teeth strip making a clicking noise
    bad o rings are usually where air blows out of defrost or floor only is what I have seen here.
    Sounds like you have two issues.....
    1 - air everywhere is usually a vacuum issue, most likely the o-rings inside the EATC.
    2 - DTC's 024 & 025 & knocking noise = Blend Door Actuator gone or going bad.
    Try running the EATC self diags a few times. That might temporary cause the Blend Door to start working correctly.
    Checkout this thread:
    http://mercurymarauder.net/forums/sh...ad.php?t=99619
    Feb 2011
    New Jersey
    I will run the test a few times. Right now its all good. The fact that its blowing heat thru everywhere is fine with me. I close all the vent doors and keep the temp on 85 and on the lowest setting. As long as I can get thru this winter then I'll work on this in spring or warmer weather. Lets see how long before I get the knocking again.
    Aug 2012
    Kansas City
    Could also be a broken door in the heater box, have seen that a few times at work. Hopefully not in your case cause that is expensive.
    Neil
    2003 Mercury Marauder - SB/LF
    Jul 2014
    NY
    I started having an issue about not getting enough heat. I have checked all fluids and the coolant is at the proper level. The EATC seems to be working perfectly. I have to crank up the heat up to 85 F or 90 F and it takes about fifteen minutes for heat to come into the cabin. It will then get plenty hot. There is no clicking or unusual noises in the dashboard. The temps have dropped into the single digits here, it was 9 degrees on Friday and 10 degrees this morning. Anyone else have an issue like this?
    I've been having the same issue the past few cold days. I'm pretty sure it's just an air pocket
    Jul 2014
    NY
    Sorry, I didn't mention: I did complete coolant flush and replaced the thermostat two weeks ago and it seemed to have been working fine until now. Should I flush the system again?
    Either air in the cooling system or the blend door may be sticking or slow......
    I know mine is an air issue because I get heat as soon as i rev the engine up
    I would burp the system again.. you may have air still in it.
    Feb 2011
    New Jersey
    Quote Originally Posted by 8UWITH6 View Post
    I thought about this. Hopefully its not my case.
    Jul 2014
    NY
    I actually thought it was the BDA, but I will burp the system again first.
