Page 1 of 3 123 LastLast
Results 1 to 15 of 34
Thread: Wesman's engine kaput overheated
    Jun 2004
    Toronto, Ontario
    Hello Gents its been a while. Bad news from my end, I need an engine. My thermostat failed (while i was inside a store and it was idling) and overheated the engine, drove it for a bit to see if it would cool back down, but it went into limp mode and then stalled. Had it towed to my buddy's garage and after much checking its burning coolant (white smoke at the tailpipes and smells sweet). 115,000 miles on it, many on the track, i figure this engine owes me very little.
    My buddy was asking about a re& re but i figure its too expensive with an aluminium 4 cammer.
    Before i dash off to car-part.com for a used engine ($1500-$2000 quite a few are there) I thought i would post it up in case anyone knows of an intact motor near Toronto.
    Wes.
    Wes
    Blue 300B Marauder
    Lehigh Valley, PA
    might as well find a cobra motor or a cobra remain longblock.
    When it breaks, build it stronger
    2063/3214
    5377/7838
    Jun 2005
    East Lansing, MI
    yeah that's just what he needs is a heavy low compression motor
    11.90 @ 117.5mph on 93 octane
    Igziabeher
    Sep 2006
    Louisville, KY
    Quote Originally Posted by RR|Suki View Post
    Better than a lightweight weak rodded paper weight.
    03 Marauder- 300B, non heated seats, T/C, no CD changer
    03 Marauder- 300A, Eaton Swapped, SOLD
    03 Marauder- 300A, 5544 of 7839 in 03, Trilogy #24, SOLD
    04 Marauder- 300B, SB with LF interior, 208k miles and still ticking SOLD
    Jun 2005
    East Lansing, MI
    Quote Originally Posted by Drewstang View Post
    ahh yes N/A marauders are blowing left and right from too much power...
    Anyway, Wes there were a couple on detroit area craigslist back in December, might wanna try there.
    Igziabeher
    Lehigh Valley, PA
    and what if he so happend to find one with an eaton? then that would be just what he needs
    2063/3214
    5377/7838
    Sep 2006
    Louisville, KY
    Why go through the trouble of pulling the engine and reinstalling another engine that has the same fate as the blown one? That makes no sense. The iron block is stronger, the pistons are stronger, and most importantly the rods are stronger. So the compression ratio goes down to 8.5:1, big deal. He can use 87 octane fuel if he chooses to.
    Jun 2005
    East Lansing, MI
    what... yeah I'm sure if he had a cobra motor it would of just laughed at overheating
    Igziabeher
    Jun 2004
    Toronto, Ontario
    Yep Looks like i'm headed to detroit this weekend.
    Wes
    Blue 300B Marauder
    Quote Originally Posted by wesman View Post
    Did you check with KarKraft in Livonia, Mich.?
    They always had take-out Marauder and Mach I DOHCs for sale.
    Dec 2004
    plymouth, mn
    Cobra motor NA can use regular fuel instead of premium.
    Brampton Ont
    Sorry to hear,glad your still around and
    no I don't know of any used engines..
    Purgatory, FL
    Keep us posted, Wes.
    (#6178 in black per FPIC)
    Rest In Peace:
    Paula Babineau 1/9/67-8/2/11
    Rex Weinbender
    Peter
    Jan 2008
    Orlando, FL
    I will never understand why people will spend the money for a iron block Cobra engine that will just run like ass and add about 80lbs to the front end.
    Get a stock replacement or build the one you have. How bad was the overheat? Tear the engine down, take some measurements and see what you have. Maybe you just heated it enough to pop a few gaskets and everything else is within spec. Alls you need is a gasket kit, head resurface and you are back on the road.
    Mil your head down .030 and get a tad more compression and HP out of it. Make sure you keep an eye on the theromstat from now on. I never leave a car running unattended unless it is in the warming up phase and I have to run in the house for a moment.
    My buddie started his racecar one evening and forgot his wallet.... ran in the house and heard a loud pop. He goes back in the garage and there is oil all over the floor and his engine seized. A $3 hose connection popped and all 7 qts of oil was pumped out onto the floor and it seized his $8000 engine. All because he left it run unattended. He would've seen his guages and low oil PSI warning light and saved his engine.
    Sucks.
    -2003 Mercury Marauder 300a-
  1. Overheating???
    By DarthMarauder in forum Shop Talk
    Last Post: 09-07-2007, 03:51 AM
  2. Engine Cooling Questions
    By Ross in forum Shop Talk
    Last Post: 04-26-2007, 05:22 AM
  3. New Engine, More Overheating Problems
    Last Post: 03-20-2007, 02:32 PM
  4. Help, Check Engine Light at 16K!!
    By redstripe in forum Shop Talk
    Last Post: 08-01-2005, 08:28 PM
  5. 4.6L 3V VVT Engine
    Last Post: 05-20-2003, 11:27 AM
