When exactly is a vehicle considered historic and what are the advantages/disadvantages of having historic tags?
Varies by state.
I think its passage of time--25 years & you qualify. The historic plates are cheaper, but only allow you to go to shows, car events & get the car serviced. Amazing how much service you might need when driving on historic plates.
As I stated, it varies by state. In North Carolina the threshold is 35 years. There is no (known to me) advantage in having an antique vehicle plate. It must be renewed each year at full cost. it provides no known perks. In Virginia, it is 25 years, and has a one time fee. It is permanent. However, there are restrictions as to vehicle useage. I have no specific information on other states.
Here's the scoop for Maryland .... 20 years old, no substantial modifications, and cannot be used for daily use ... just for car shows, parades, club activities, etc.
Historic:
To qualify as a historic vehicle, your vehicle must not have been substantially altered, remodeled, or remanufactured from its original construction, and must be 20 model years or older.
A historic vehicle 60 years or older may obtain a one-time, permanent, non-transferable registration. This vehicle registration does not qualify for specialty plates.
Vehicles classified as historic certifies the vehicle will be maintained for use in exhibitions, club activities, parades, tours, occasional transportation and similar uses. The vehicle owner further certifies the vehicle will not be used for general daily transportation or primarily for the transportation of passenngers or property on highways. You will need to fill out the Application for Historic or Street Rod Registration (form # VR-096).
Maryland used to be a 25 years old vehicle for "Historic" classification.
They changed it a few years ago to only 20 years old.
You also are exempt from emissions testing in Maryland....
25 yrs old in New York State.
Registration was $23.00 per year and was just doubled.
2003 Marauder 300B,
Heated Seats
35% Tint
Mercury All Weather Mats
1973 Oldsmobile Toronado
2012 Kia Sedona Van
2008 Corvette Convertible
2021 Prius Prime Limited
Member # 440
----- John
25 years in NJ for QQ plates(historic). Limited use and with the QQ plate you can qualify for cheap insurance. Buddy of mine has a 65 Chevy p-up and pays like 150 bucks a year. In NJ 150 is really cheap insurance.
30 years for Florida, one-time registration.
2007 CVPI & 2004 Marauder 300A
Thanks for the input. Just wondering when the 20 year mark started, from build date or what?
Some states (Ohio included) have "collector" plates which does not limit based on age, but on collectibility.
