Results 1 to 15 of 18
Thread: Volt gauge Problem
    May 2003
    Wichita Kansas
    Volt gauge Problem
    I noticed when on my way to work this morning that my volt gauge was black but the OP gauge was lit,i tapped on it and it came on now the volt gauge is really dim and the op gauge is bright, any suggestions on what this could be. If I have to pull the gauge panel anyopne have a write up to give me some help?Thanks guys
    Joe
    Rockford
    volt guage out
    Hey 03mercmarauder,The way you describe the problem,It makes me think there is a bad connection (loose wire)or somthing to that effect.No warranty left??
    Bradley G
    May 2003
    Wichita Kansas
    no warranty left on the car, only thing I have a warranty left on is the mototr, it worked just fine last night and all the sudden this morning its starts acting up.
    Long Island, NY
    Quote Originally Posted by 03MERCMARAUDER
    It sounds to me like a loose ground wire.
    2003 Marauder 300B,
    Heated Seats
    35% Tint
    Mercury All Weather Mats
    1973 Oldsmobile Toronado
    2012 Kia Sedona Van
    2008 Corvette Convertible
    2021 Prius Prime Limited
    Member # 440
    ----- John
    Dec 2003
    Cape Cod, MASS
    Joe
    Possible Alternator
    St. Clair Shores, MI
    When you increase engine speed do all of the lights get brighter or is it just the oil pressure guage? If they do, you probably have the voltage regulator going bad. The worse part is that the regulator is internal to the alternator. So you have to get a new alternator.
    2004 Marauder/ 1994 Thunderbird SuperCoupe/ 1983 Mustang GT
    May 2003
    Wichita Kansas
    The rest of the gauges are fine just the volt gauge is dim now.
    loose ground, loose bulb, or bad bulb
    ^^^what 'Nut said^^^
    The gauge pod is relatively simple to remove. Just pull down firmly at the back of each "wing"...it's held in place by those "alligator" clips. Once loose, you'll need to put the shift lever in "D" to make enough room to rotate the pod up and out. Each gauge has its own connector, but don't worry about which is which; they're all different. Installation is just the reverse, it snaps in place...
    May 2003
    South Fl
    Is this a stock volt gauge?
    Purgatory, FL
    Arrow possibilties
    If your problem cannot be fixed, how about replacing both guages? The oil pressure guage is just an "on/off" deal (no real reading). The new guage comes with the sender for true pressure readings. The lights in the volt guage match the new oil pressure guage. Summit has these for a total of $100.00. Part #s are : volt meter: atm4391, oil: atm4327. Keep us posted.
    Just my .02 and then some.
    (#6178 in black per FPIC)
    Rest In Peace:
    Paula Babineau 1/9/67-8/2/11
    Rex Weinbender
    Peter
    May 2003
    Wichita Kansas
    If the gauge cant be fixed thats what I am gonna do, i am gonna swap out the op guge anyway, thanks for letting me know how the gouge panle comes out i looked at it today but didnt really try to get it off, I might just not put a volt gauge back in there maybe a tranny temp gauge. I am gonna tear into it tomarrow after work, thanks for the help guys, i will let you know what I find
    New York City
    Quote Originally Posted by RoyLPita
    Are you serious RoyLPita, or are you poking fun at it's accuracy?
    Quote Originally Posted by Zim Hosein
    It's true. Notice the pressure is always the same, whether the car is hot or cold? Many old discussions can be found on this topic.
    New York City
    Thanks for the quick reply FordNut, the reason I asked was because on my old Camaro, the oil pressure guage stayed the same as long as it had the proper amount of oil in the engine
  1. Oil Pressure Gauge Conversion Part 1 of 2
    Last Post: 09-09-2019, 01:38 PM
  2. Summit Performance digital gauge cluster
    Last Post: 08-22-2004, 10:33 AM
  3. EGT gauge and Air/Fuel gauges? Good idea or waste of time?
    Last Post: 07-07-2004, 06:42 AM
  4. Dual A-Pillar Gauge Pod
    By Constable in forum Shop Talk
    Last Post: 04-29-2004, 06:27 PM
  5. oil pressure gauge
    Last Post: 10-28-2002, 12:02 PM
