Page 1 of 4 1234 LastLast
Results 1 to 15 of 53
Thread: Has anyone purchased a helmet?
    Hiram, Georgia
    Exclamation Has anyone purchased a helmet?
    Okay folks, while this thread will likely be less exciting than the politically oriented or the "big brother is watching you!" threads which keep popping up, I need some help.
    With the thought that I may actually get out of the office once or twice this summer to run at the track, I have started looking at purchasing a helmet.
    Some of the helmets are pricey and some are reasonable. I am not clear what goes into the cost.
    Also, what is the difference between Snell SA 2000 and Snell M 2000 compliance? Is it just that the "SA" designated helmets are fire retardant? Are both of these designations acceptable at an NHRA certified track like Indy?
    Should I go with a closed face helmet or will an open helmet be more suitable? (I do wear glasses when I drive).
    Is there anything else that I need to know?
    Thanks for any help you can give me!!
    This is the one I will be getting from Summit today. I've got this thing about buying used....it's like wearing another mans shoes.....
    Bell open face SFI 31.1@ $209, used to be onsale for like $153....
    INFO:
    "Comfortable and safe.
    Helmet, Mag 4, Racer, Open Face, Snell SA 2000/SFI 31.1, Medium, Black, Each
    The Mag 4 helmets give you Snell SA 2000 protection, plus the comfort and classic look of Bell's open face design. The helmets have a strong Kevlar chinstrap and ThermoFlex™ shell, which combines hand-laid lamination and thermo-set resin for strength. The interior of the helmets features a fire-resistant, high-performance fabric. They're available in white and black."
    2017 Niro
    The NHRA rules state the following....
    "Drivers in all 13.99 (*8.59) or quicker cars, and Dune buggy type vehicles running 14.00 (*8.60) seconds or slower must wear a helmet meeting SNELL 85, 90 or SFI 31.1, 31.2, 41.1 or 41.2 Specs or BSI BS 6658-85 type A (including all amendments) Specs. Driver's in supercharged front-engine open-bodied cars must wear a helmet meeting SNELL SA95, SA90 or SFI 31.1 or 31.2 Specs or BSI BS 6658-85 type A (including all amendments) Specs. See General Regulations 10.7."
    REG.10.7.
    As outlined under Class Requirements, drivers in all classes must wear a helmet meeting SNELL or SFI Specifications or BSI BS 6658-85 type A (including all amendments) Specs.
    SFI Spec 31.1 = SNELL SA, open-face helmet.
    SFI Spec 31.2 = SNELL SA, full-face helmet.
    SFI Spec 41.1 = SNELL M, open-face helmet.
    SFI Spec 41.2 = SNELL M, full-face helmet.
    Drivers of ET cars (13.99 or quicker) must use a helmet meeting SNELL 85, 90, 95 or SFI 31.1, 31.2, 41.1, or 41.2 Specs. Exception : drivers of open bodied, supercharged, front-engine cars must use a helmet meeting SNELL SA90, SA95 or SFI 31.1 or 31.2 Specs. Effective 1-1-2002, the acceptance of SNELL 85 helmets will be discontinued.
    Drivers in Top Fuel, Funny Car, Pro Stock, Top Alcohol Dragster and Top Alcohol Funny Car must use a helmet meeting SNELL SA90, SA95 or SFI 31.2 Specs, except as noted under Class Requirements. Effective 1-1-2002, the acceptance of SA90 helmets will be discontinued. See Class Requirements.
    Drivers of any open bodied car wearing an "open face" helmet, must wear protective goggles. Modifications to helmet/visor/shield are prohibited. All helmets must have the appropriate certification sticker affixed inside the helmet.
    2017 Niro
    Hiram, Georgia
    [b]Drivers of any open bodied car wearing an "open face" helmet, must wear protective goggles. Modifications to helmet/visor/shield are prohibited. All helmets must have the appropriate certification sticker affixed inside the helmet.
    I take this to mean an open face helmet like you picked is acceptable.
    The Bell RS-5 is like the one you picked, only it is a full face version. Any thoughts on the benefits/detriments of that?
    Yessir....the spec 31.1 open face is the affordable acceptable way to go.
    The only exception is if you are racing open cockpit and you must add the visor or gogles.
    I am gonna have my airbrush friend do some neat graphics on it as well.
    2017 Niro
    Aug 2003
    Affordable Detroit
    Go with the closed face helmet because it allows for a open casket funeral.
    Dan
    Jul 2002
    Richmond, VA
    Marty,
    Open faced is what I got. I bought it at Morosa Race Track in Florida. For what we are doing a open face basic helmet is fine. Even if you running in the 11's the likely hood of flipping your car is slim. If you are totally obsesed with safety buy a closed face helmet.
    jet
    2003-300A
    Trilogy #8 with Custom Pulley Produces 12.4psi of Boost
    407 RWHP and 384 RWT
    Best 1/4 Mile 12.028 @ 117.01mph
    From Lidio: Trilogy #8 install & Custom Tune, Custom Pulley, Chip, Accufab Throttle Body, Baer Claw Front Calipers with Crossdrilled & Slotted Rotors All Around, Custom 2¼ X-Pipe, 3 Chamber Flomaster Mufflers, Widened Rear Rims with 305 Nitto NT-555R Extreme Drag Radials, Auburn High Performance Posi.
    From Reinhart: 4.10 Rear Gear, 180 Degree Thermostat, Motorcraft Plugs, Metal Matrix Driveshaft, Rear Sway Bar.
    From Metco: Carbon Fiber Intake Tube, Control Arms & Watts Link.
    From Others: Kenny Brown Braided Brake Lines & Dead Pedal
    Hiram, Georgia
    Quote Originally Posted by dwasson
    What a weenie!
    Hiram, Georgia
    {color me jealous!}
    Port Charlotte, FL
    Marty,
    Back when I was allowed to ride motorcycles.....
    I bought the full face unit from Shoei, on sale for $300.00.
    I wear my glasses once and awhile, and there is no problems, I always wore my sunglasses under the sheild too, except at night of course.
    I'd go full face.
    Wanna buy my helmet? Trade? We both got big heads, so it should fit!
    04 Crown Victoria Sport
    1995 F150 4x2 4.9 5spd
    Hiram, Georgia
    Quote Originally Posted by Rich_Long
    Trade?
    For what? Can I give you Todd??
    Aug 2003
    Birmingham, Alabama
    Quote Originally Posted by martyo
    He'll take Todd and $300.
    Mar 2002
    Round Rock, TX
    I'll post a pic of my Black Full-face MM.net helmet I did up. I just used a Black HJC Full Face w/visor. With the mm.net logo's on there, I'm a complete badass.
    Aug 2003
    Affordable Detroit
    Quote Originally Posted by Donny Carlson
    Or $250 and you keep Todd.
    Dan
    Blog Entries
    2
    I got mine from JC Whitney Snell approved, open faced for $80+. Well made and very pleased w/ it.
