Page 1 of 3 123 LastLast
Results 1 to 15 of 33
Thread: Kooks on a Trilogy car
    JFB Guest
    How much horsepower or performance difference can you expect by going to Kooks headers with the stock exhaust from the mufflers back, on a Trilogy equipped Marauder? Who has the best deal on the Kooks?
    May 2004
    North Louisiana
    Quote Originally Posted by JoeB
    I may be up for some too. Maybe a group buy?
    05 - SRT-10 Truck, Viper V10, 6-Speed, 92 of 200 in white.
    06 - Mercedes R350
    65 - Mustang Convertible
    03 MM:
    Black, Cd Changer. Sold
    Current Mods: Vortech air to air supercharger #1, SCT B2400 MAF, 42 lbs. Injectors, K&N, Custom Air box, Twin Cobra Fuel pumps, Stage II trans, PI 3000 Stall Converter, MM drive shaft, DR cooling mod, FRPP 4.10’s, FRPP girdle cover/stud kit, Motorcraft Plugs, 180 Stat., 9100 SCT, Mac n' Zack Rear Control Arms, Full Kook's exhaust..
    Connecticut
    I would think that the best deal on a Kooks exhaust system can be had directly from Kooks, but I could be wrong. But since my car is only puting 400 HP to the wheels w/the Kooks system and the Trilogy set-up is intended to put 385 HP to the wheels w/an otherwise stock Marauder, then I'd say that I've only gained about 15 RWHP from the Kooks system once my car was S/Cered. But the Kooks system does make the car sound sooooo NICE!!!
    Dec 2003
    My car is Trilogy/Kooks equipped.
    It made 426rwhp/407rwt.
    I have a plasma booster module and a smaller pulley...so my educated guess is that it should be around 400-410rwhp depending on other minor mods...intake, etc.
    A Kooks exhaust on a Trilogy machine makes an amazing sound.
    Silver 2004 Marauder
    Trilogy #48 (SOLD April 2014)
    1984 Mustang GT, stock, 60,000 original miles (SOLD August 2013)
    2017 Ram Rebel 1500, Silver: 5.7 Hemi, Lots of extras...
    Previous: 2014 Durango R/T
    MI2QWK4U Guest
    Quote Originally Posted by FiveO
    Ok, you got me...whats a plasma booster? The kooks are actually my next mod....
    Connecticut
    Quote Originally Posted by MI2QWK4U
    Yeah, he lost me w/that "plasma booster" comment too. is that like a blood booster? Anyway, Dave, you probably already know this, but incase by chance you don't, let me suggest that you check w/Lidio to ask him if a chip re-burn is needed w/the Kooks exhaust since your car is S/Ced. It might require a different air/flow ratio setting.
    Jul 2002
    Richmond, VA
    Well this is the first time I've posted it but since adding the Kooks and a few other goodies from Lidio my Horse power has gone from 407 to 460 and my torque is has gone from the high 380's to just shy of 440. I thought my car was fast before but now it is scary. My best 1/4 mile times with the new power are 12.02 @ 117mph.
    2003-300A
    Trilogy #8 with Custom Pulley Produces 12.4psi of Boost
    407 RWHP and 384 RWT
    Best 1/4 Mile 12.028 @ 117.01mph
    From Lidio: Trilogy #8 install & Custom Tune, Custom Pulley, Chip, Accufab Throttle Body, Baer Claw Front Calipers with Crossdrilled & Slotted Rotors All Around, Custom 2¼ X-Pipe, 3 Chamber Flomaster Mufflers, Widened Rear Rims with 305 Nitto NT-555R Extreme Drag Radials, Auburn High Performance Posi.
    From Reinhart: 4.10 Rear Gear, 180 Degree Thermostat, Motorcraft Plugs, Metal Matrix Driveshaft, Rear Sway Bar.
    From Metco: Carbon Fiber Intake Tube, Control Arms & Watts Link.
    From Others: Kenny Brown Braided Brake Lines & Dead Pedal
    Connecticut
    I think that even though the Kooks system has given your car some more power, much more of that extra power is due to the high boost pressure your pushing w/that smaller pulley you've chosen. You went from 9.5 PSI to 12.4. A 3 PSI gain in boost is quite a significant jump. So I think that if you did that even w/out the exhaust, you still would've been at 445, or 450HP.
    It is an ignition spark enhancer. When I tried it I didn't get any increase in hp/tq at the peak numbers, but picked up about 10 ft-lb tq at lower rpms.
    Dec 2003
    Previous owner had the plasma booster module put on...I didn't.
    Here's a link:
    http://www.ignitionsolutions.com/
    Dec 2003
    Quote Originally Posted by JET
    Nice numbers JET...looks like another 11 second Marauder isn't too far away!
    Jul 2002
    Richmond, VA
    The info in my signature is all before the kooks install. The pulley was already on .
    2003-300A
    Connecticut
    So then you're saying that your car gained 53 HP at the wheels from the Kooks exhaust alone? Can that be right? I've never heard of that on a S/Ced engine. If that's true, then maybe the headers and freer flowing exhaust benefit the 4.6L engine more once you get to a certain boost level. Is your 460RWHP figure on pump gas just like your 407HP figure was? And were both of the 407 HP and 460 HP dyno runs calculated in "S.A.E. corrected" figures?
    MtClemens, MI
    Best I can tell is that Kooks are worth about 20-30 RWHP on a MM that has a Trilogy making the stock 9.5psi of boost.
    This is of course putting the Kook’s on a Trilogy MM that already has a better then stock MM muffler. And when we’ve done Kook’s… It’s been Kook’s and a 2.5” X-pipe with two high-flo cats plus upgrading the rest of the system to 2.5” as well. So to some extent it’s more then just a long tube header that’s being added to the car.
    And on Trilogy cars that are upwards of 12-14psi, the full exhaust deal with Kook’s will net even greater gains at rear wheels.
    Most of the Trilogy equipped MM’s that I’ve done now that are in the 13psi range, full 2.5” exhaust with Kook’s, good mufflers, better MAF will make about 450-470 RWHP and near 500RWHP with 100 unleaded race fuel tunes in them. This with 4.10’s and the stock, tight torque converter makes these cars go low 12’s, high 11’s with good traction and cool air.
    Thanks
    Lidio Iacobelli
    Alternativeauto.com
    (586)-949-7505
    Dec 2003
    Quote Originally Posted by Lidio
    Snip....
    Thanks
    Man's gotta have a goal...thanks for the info Lidio.
    I found a 24 hour station in my town that has 93 octane. Also found another station (non 24 hour) that has 104 unleaded racing gas
    Might be calling next summer for a few minor changes!
  1. Car Show In Kokomo
    By MERCMAN in forum The Classic Lounge
    Last Post: 08-28-2004, 12:18 PM
  2. Kook's Headers/exhaust results:
    By BillyGman in forum Exhaust
    Last Post: 12-18-2003, 11:05 AM
  3. trilogy car goes 13.08
    By keyboardracer in forum Trilogy Motorsports
    Last Post: 11-19-2003, 05:04 PM
  4. Welcome Kook's Custom Headers!!!
    By Logan in forum News
    Last Post: 09-29-2003, 10:37 AM
