Oil pressure gauge swap
Originally Posted by
RF Overlord
The stock gauge is back-lit through the numbers and the primary indicator lines. The replacements are perimeter-lit with a solid (opaque) face.
Norm, except for the tiny bit of black rubber glommed onto your trans temp gauge, your gauge pod looks identical to mine.
Thanks Bob. I left that there for when I take the pod out, so I can lay the assembly down without dinging that side of the gauge. I somehow stupidly dented that side of the bezel (those aluminum bezels are really easy to deform), and that covers the ding and keeps a buffer in place.
Something else I have to fix? That plastic on the area just above the pod scratches like crazy. Just touch it and something flakes off. I know they sell some paint that’s a close match, and someday I need to get everything off and paint it.
