Results 1 to 5 of 5
Thread: Any car audio geniuses or EEs in here? Head units, amplifiers, CD changers, oh my!
    Oct 2019
    Washington
    So I got in a little over my head here thinking I could easily integrate a car audio system and connect my phone (hardwire) to a factory head unit. The cassette player is very charming and I don't want to replace it with a different head unit, and I'm sure many of you understand that. I have a lightly spec'd system with new door speakers and a powered sub. My car doesn't have the factory CD Changer or subwoofer. I've seen the PIE FRD03-AUX unit (which converts an RCA signal to the 16 pin CD changer input), and pending great luck that I found a place online with one in stock, that'll work great (albiet with what looks like a need to attenuate it into the head unit). But I am highly skeptical that they have some old drop shipping spreadsheet they're using and after I order this thing in a couple days they're going to tell me it's out of stock.
    So if I can't get a hold of that thing, I saw on a BMW forum someone had another solution that seemed promising.
    1. iPhone > JL Audio bluetooth receiver to RCA out (this is spec'd for marine audio, which I suspect is properly attenuated\level matched for aftermarket amplifier levels)
    2. RCA out (unknown signal level currently) SPLICED into CD Changer audio wires (currently unknown level)
    3. Not sure how I need to terminate the CD changer audio wires, or if at all.
    From what I understand, inserting a CD into the head unit disables all input from the CD Changer. And if I take the CD out, but select CD and the changer signals to the head unit that it has a CD (assumed), then it will play from the changer (I know this is the correct behavior, but don't know how the head determines it completely).
    This is ideal.
    There's only a couple issues I have to unwind.
    1. The PIE FRD03-AUX unit, and actually several across different car brands seem to have some complaints over "distortion." This seems to be a level mismatch between the RCA output and 16 pin input on the back of the head, shoddy engineering on PIE's part.
    2. I do not know the expected output level of the CD Changer into the 16 pin connector into the head unit (though I can level match this by comparing it to CD output from the head)
    3. SOLVED - The head unit does not output levels that the aftermarket amplifier will expect, so JL audio makes a very nice line attenuator for this purpose.
    So if I can get anyone in here that either knows, or is willing to measure
    A. Audio output level from the CD Changer (that is the two audio wires in the 16 pin connector out of the CD changer into the back of the head unit)
    B. What signals the changer is sending to the head unit that may be of concern with this idea
    Any help is very much appreciated, I am at the mercy of this shoddily designed part right now and don't want to hack the car up and take away its charm.
    Oct 2019
    Washington
    Alternatively, it looks like Soundgate SDSFord might be a replacement for the PIE FRD03-AUX, just without the cable to connect to the changer wiring. So instead I would just buy the SDSFord module & a CD changer wiring harness.
    Does anyone know the CD changer wiring harness part number? Or places that will build to spec\pinouts?
    If I have to get a CD changer, is there anything fancy to power it? Is there two harnesses then? One to power the unit and another to the head unit?
    Oct 2019
    Washington
    Okay I think I got this figured out.
    SOURCE 1 : Stock head unit > JL attenuator (set to match JL Marine output levels)
    SOURCE 2 : JL Marine Bluetooth Unit (assumed to be outputing correct levels for aftermarket amp)
    both of these go into an RCA switch, then into the aftermarket amp. Then I don't have to futz with the levels in the PIE\other adapter units. Now only issue is finding an automatic RCA switch I can trust. Alternatively, if that doesn't work out, I suppose I can just keep the bluetooth connection wired until I get around to getting the factory head unit working again. I am worried about *****y grounding with these automatic RCA switchers.
    Winston Salem, NC
    There are some wiring gurus on here...Here's to hoping they can help out! Most of us have chucked the factory unit when we went with Carplay/Android Auto...tech has just come sooo far over the years! We hope you get it friend, we are for you!
    2003 300A
    Eaton Swapped by Curless
    Brake Upgrade
    Mo's Tune
    JLT Intake
    Addco Sway Bars
    ADTR Coil Over Suspension
    SW Headers and Exhaust
    Accessories By FastBlackMerc
    4.10 Gears
    Aeroforce Gauges
    Pantherlights Headlamps
    Oct 2004
    A fix for old tech is never 100% in terms of performance. Change the old head for new tech.
  1. Alpine and JVC head units for sale CHEAP$
    By k9t8m in forum Marauder-specific Parts for Sale
    Last Post: 12-02-2008, 12:44 PM
  2. Pioneer F Series Head Units
    By HiHo in forum Pops Stereo
    Last Post: 05-27-2008, 06:15 AM
  3. Aftermarket head-units, whaddaya guys got?
    By Steve in forum Community Discussion
    Last Post: 09-01-2007, 10:12 PM
  4. On the Topic of Double Din, In dash Touch screen Head Units
    By LVMarauder in forum Community Discussion
    Last Post: 01-30-2007, 08:51 PM
  5. MM Stereo Head units
    By scherermaddness in forum Community Discussion
    Last Post: 10-14-2003, 05:05 AM
