Results 1 to 4 of 4
Thread: Next Fuel System Mod: FRPS Dampener
    I haven't popped a Fuel Rail Pressure Sensor (FRPS) yet, but it commonly happens to some of the 'stangers. One fix is to install this flow restrictor disc (dampener) in the fuel rail. It drops in the hole under the FRPS and prevents the sudden pressure spikes from popping the diaphragm. Get 'em from Kenne Bell.
    Another false start... It won't work with aftermarket fuel rails. The hole for mounting the FRPS doesn't have a step to keep the dampener from dropping into the fuel rail.
    Hiram, Georgia
    So, did it fall in?
    Quote Originally Posted by martyo
    So, did it fall in?
    I measured first, so no it didn't. If/when I develop problems with blowing FRPS I'll design another method.
  1. Fuel System Upgrade
    By FordNut in forum Shop Talk
    Last Post: 12-19-2007, 02:34 AM
  2. Please don't yell at me....
    By natedog1284 in forum Shop Talk
    Last Post: 05-01-2006, 07:46 AM
  3. Superchargers only Please
    By MarauderMark in forum Community Discussion
    Last Post: 02-19-2006, 08:07 PM
  4. This may not be popular(concerns fuel flow)
    Last Post: 01-22-2006, 04:15 AM
  5. MPG Increases, Saw it on another Site.
    By gray bear in forum The Lounge
    Last Post: 08-24-2005, 12:36 PM
