What size are the original fuel injectors?
24lbs i believe?
That's all I thought they were closer to 30? Thanks for your help.
Great, now I have to spend more money to get bigger injectors. When will it end? Sometimes I wish I did not like cars, I would have more money in the bank if I didn't.
what are you doing exactly?
Yep, they're 24 lb.
Just slowly building my way up to a supercharger and or nitrous. It needs the stainless works exhaust system but, I don't have that kind of money. I guess I am putting the cart before the horse so to speak.
For a supercharger you need a minimum of 39ib
A legend quote a True Ride can not be no Rider without a Marauder
Finally Eatonized by ZackZillaaaaaaaaaaa!
Cardomain link: http://www.CarDomain.com/ride/3380944
A bank is a place that will lend you money if you can prove that you don't need it
What size are you running ImpalaSlayer?
Right now their stock but the car has minor upgrades. Tb, Undr pulleys, k&n, programmer, bigger fuel rails. I don't have the money for a complete supercharger kit right now but where can I get used injectors? Here on the website?
