Results 1 to 11 of 11
Thread: Rear axle repaired
    May 2010
    hollywood florida
    Rear axle repaired
    I finally fixed rear axle I was able to salvage my old axles by using a bearing relocation I moved bearing just past the wear point of the old bearings and walaa fixed all for cheap money
    Jan 2008
    Long Island New York
    That`s on my to do list as well
    current owner of 2004 Trilogy #45 (since 2009)
    and just added the POPPAJ Silver Birch to the fleet
    (8-2010)
    Yes I am hooked
    And you'll be replacing the bearings soon.......
    Aug 2007
    las vegas
    Long story short, I had mine done a couple of weeks ago, $1300.00, everything new.
    Aug 2010
    West Salem, WI
    You'll be tackling this again at some point
    Aug 2009
    Florida Keys
    Quote Originally Posted by WI Fordguy View Post
    Yup, moving the contact point won't fix bad metal.
    Rockauto had the hardened axle kits with bearings and seals for $200ish. One time, done. not going back.
    It's all BS until you can show me the time slip!
    Trilogy #36
    #2529 of 7839
    See Garage for mods.
    O bsessive
    C ar
    D etailer
    SOLD
    2014 Caddilac CTSV Wagon
    CAI
    DRs
    11.70 @ 119 mph
    505 RWHP at Mo's untuned.
    10/16 mods
    Ported blower. LTs catless mids, flex fuel kit, pulleys, badness.
    621/626 on E49 tuned for E85
    10.65 @ 128.9 SSHS16
    Yep, temporary repair. Didn't do the necessary research...
    There was a TSB from the factory, some early Marauders left the factory with axles that weren't properly hardened, leading to premature wear at the bearing contacts. Moving the contact point will just wear another spot. Gotta get properly hardened axles to permanently fix it. Some of us got ours repaired under warranty way back in the day...
    Sep 2008
    USA
    I used those "repair" or offset bearings on my MGM, and have had no issues.
    I think my axles are different than the ones in question, though...
    Ex Panther Owner
    Yeah, if bad bearings damage good axles the offset bearings will do ok. If bad axles cause the problem then replacing them is the only real option.
    May 2010
    hollywood florida
    Look the repair is solid ok if the axle was bad off then yea I would have replaced the new bearing and it's location is just fine take ur negative post else where
    You'll learn.
  1. Rear axle
    By Blancosmarauder in forum Shop Talk
    Last Post: 10-29-2010, 06:43 AM
  2. 28 spline rear axle
    By Georges93LX in forum Marauder-specific Parts for Sale
    Last Post: 12-13-2008, 03:02 PM
  3. Rear axle
    Last Post: 11-04-2008, 09:38 AM
  4. Wanted: 03+ rear axle
    By Culedood47 in forum Marauder Parts/Misc. Wanted
    Last Post: 01-18-2008, 04:20 PM
  5. Rear Axle Girdle
    Last Post: 01-19-2004, 03:26 PM
