ive been trying to program a key fob but the mm wont go into program mode does anyone have the right way to program this 03 mm or no were i can get a door module for driver door maybe thats whats bad as well tks
Doors closed, key/on/off/on/off/etc... ending in OFF I believe 8 times. Doors will lock/unlock to initiate programming. Press LOCK on each remote being programmed. Done.
2004 Mercury Marauder
2,187 of 3,214
997 in Silver Birch
448 with light flint interior
304 with heated seats
336 with sunroof
well i tried that and nothing the mm wont go into program mode the locks wont cycle
Hmmmm........
2,187 of 3,214
997 in Silver Birch
336 with sunroof
yes ive pullin my hair out trying to figure out why it wont program
http://www.programyourremote.com/cla...yAd.asp?id=885
Hope this helps the timing is crucial
2004 90k #924 of 1237 sequence #2572 Black E3 sparkplugs accel coil packs 140034-8 trans-dapt throttle body spacer Mmr manifold spacer cold air intake superchips Steeda underdive pulleys xcal3 programmer stock other then that
Mine goes into "program mode" after 4 ON/OFF cycles as indicated by the locks cycling. However, when I push a button on the new, and even the old, remotes, nothing happens. Nothing programmed. It's broked. :-(
you tube was my friend
Those were the days.........
DANG THEY'RE CUTE!!!!!!
Smile and Nod
I love THIS bar
I'm having trouble with this too. Bought my remote on eBay, the vehicle application chart stated Marauder was compatible, but the instructions included did not mention Marauder. Since CV/GM had identical instructions, I assumed all Panthers would be the same. I've tried 3 or 4 different program instructions, but the door locks don't cycle on any. Does anyone have definitive info on this? Wht do dealers typically charge to program the remote?
Are you sure you have the right fobs? They are marauder specific.
2003 DBP/LF - # 36 sold
2003 DBP/LF - # 205 sold
2004 Black - Trilogy #43
2003 Black - sold
2004 DTR - sold
If the FCC # doesn't match this, it's not going to work.
2003 Black - sold
2004 DTR - sold
Finally figured it out: I wasn't turning the key fast enough. Here's how it works.
Put key in ignition.
Turn key from off to run (not start) 4 times AS FAST AS YOU CAN. Door locks will cycle to indicate car is in program mode.
Immediately press any button on the remote and door locks will cycle again. Up to 4 fobs can be programmed one right after the other.
Turn key off and door locks cycle again to indicate programming is finished.
Ah crap!! My fob FCC code ends in 345
Aaron "Scooter" Hatfield
2003 Mercury Marauder
Tucson, AZ
