Page 1 of 6 123456 LastLast
Results 1 to 15 of 79
Thread: Engine tapping hard at idle and all RPMs.
    Apr 2005
    Queens NY
    Unhappy Engine tapping hard at idle and all RPMs.
    Last week, #2 spark plug blew out again. It shorted the coil and took the threads. It was the same one that blew out on my way to Indy last year. I was able to re-thread it last time but no such luck this time around. I purchased the insert kit for the head to replace the plug. Today we installed the insert with no issues. We made sure we blew out all the metal in the cylinders several times like in the instructions. A new coil was installed and when we started it up, it started making a loud tapping noise out of #2 cyl. I can unplug the coil and the tap changes tone and then gets louder when I plug the coil back in. I hear it in the intake not in the exhaust so it may be valve related.
    I removed the intake manifold and looked at the intake valves and they are clear and clean. I also blew out all the cylinders and took the plug back out to clear any debris. I also did a compression test and was pushing about 170 in that cyl so I'm pretty much at a loss at the moment. Tomorrow I plan on pulling the valve cover and see what it looks like under there.
    Ill try to take a video tomorrow. Basically it sounds like a hammer being hit on the inside of the intake manifold. The engine idles smooth and don't miss, it just has the loud tapping all the time.
    I hope to find someone in the area that know what they are looking at with these engines and know how to tear them down.
    2003
    MERCURY MARAUDER 300A
    Build Date
    5/31/02
    Sequence#
    #363 of 7839 Black Marauders
    Dyno tested power
    Best 1/4 mile time to date
    12.456@109mph
    Visit my Garage
    Blackened300a's Garage
    The Dirty South
    Best of luck getting her repaired.
    Nov 2009
    Fort myers
    Keep us updated I think I heard a similar noise just yesterday from right by heck as a matter of fact cylinder #2! Ima check now because I hope it was just a coincidence of me losing a wrench under the hood
    Nov 2007
    NorCal
    This brings back bad memories that still haunts me today. Question though did you put in a heli coil or steel insert the last blow out?
    Good luck.
    2003 Mercury Marauder 300A
    FRPP BOSS50 Block w/MMR 900S Stroker 5.3L DOHC 324ci 10:1cr - (321rwhp/360.5rwtq) - Tuned by AED
    2006 Ford Mustang GT
    FRPP FR3 Handling Pack|FRPP X Pipe w/GTA Exhaust|Steeda CAI|Hurst Shifter
    (289rwhp/307rwtq)
    2003 Chevrolet Suburban 2500 LQ4 6.0L LT 4WD
    Cognito leveling Kit, Fox 2.0, BFG KOA2 Radial All Terrains, Magnaflow, K&N and 4.10 gears
    Apr 2008
    Conneticut U.S.A.
    I supose there is a chance that the old heli coil got caught and crushed in one of the valves.
    But I hope your looking at a much easier situation to handle than a tear down and repair.
    Assembled 12/17/2003
    #1183 of a build of 3214
    and is #379 of 1237
    Link to Mod's and car:
    There is a complete engine for sale in the classifieds.
    Apr 2005
    Queens NY
    Quote Originally Posted by dohc324ci View Post
    Good luck.
    The last blow out didnt take the threads. I t must have backed itself out and I was able to save re-insert the plug.
    Quote Originally Posted by LeoVampire View Post
    Im exploring all options. I have $3500 set aside to repair this.
    Im keeping all options open. Tomorrow I will look to see under the valve cover if its a valve or piston.
    2003
    Build Date
    5/31/02
    Sequence#
    Dyno tested power
    12.456@109mph
    Visit my Garage
    damn dude sorry to hear. that really sucks.
    Apr 2003
    Rock N' Roll Hell
    Sorry to hear this Paul.
    Good luck!
    "Bye Bye, Johnny B. Goode."
    Apr 2008
    Conneticut U.S.A.
    Before you tear it down do a leak test if you can to try an pinpoint the problem between the exhaust, intake and so forth.
    How well are you set up for tools and equipment @ your place?
    and is #379 of 1237
    Pull the cam cover and check if one of the 2 followers came off and is making the noise.
    The car will run just the same with one off due to it having 2 valves per intake/exhaust
    That is what I'd suspect.
    Apr 2005
    Queens NY
    I found a really good Ford mechanic local to my shop. I drove the car the few miles and it ran great, no loss of power, no hesitations and nothing abnormal other then the noise. The guy heard the noise and said it sounds like the typical wrist pin slap after detonation. Hes pulling it apart to inspect further into it. I should have a call this afternoon to see what the damages are.
    2003
    Build Date
    5/31/02
    Sequence#
    Dyno tested power
    12.456@109mph
    Visit my Garage
    Feb 2009
    Upstate NY
    Sucks man, sorry about that. I hope it's not major.
    03 300A - Number 1727
    damn that sucks dude. i got half way to work today and turned around because of a loud clanking sound .
  1. Tapping at idle
    By NYGarageQueen in forum Shop Talk
    Last Post: 05-02-2010, 04:53 PM
  2. Engine tapping or ticking
    By Paul in forum Shop Talk
    Last Post: 06-09-2008, 09:06 PM
  3. Tapping sound in engine
    By Billy Mac in forum Windy City Marauders
    Last Post: 07-08-2004, 08:51 AM
  4. Update on engine tapping/ticking noise on 04
    By junehhan in forum Community Discussion
    Last Post: 04-19-2004, 09:42 PM
  5. Wierd tapping noise from engine.........
    Last Post: 01-31-2004, 10:19 PM
