Results 1 to 15 of 20
Thread: Rattling in front of engine
    Jul 2016
    Michigan
    Hey guys, I'm me to this forum so I'm probably posting something that's already been discussed. I'm just not sure how to navigate the topics. But, my 04 silver MM rattles on startup like something's not engaging. It starts up and runs fine. Sometimes it doesn't rattle and other times it rattles while in driving. The noise is coming from the front of the engine... Maybe alternator area of the engine. Any idea what it is?
    Sent from my Z981 using Tapatalk
    welcome to the club, you should get some interesting responses on this one, I hear those silver ones are fast.
    Quote Originally Posted by Cabotwick View Post
    If it is an intermittent Clickety-Clackety-Clickety noise that only happens when the fan cycles on ... it may be a cracked ring around the inside of the fan shroud that the fan blades contact and wobble or bind up. Just had this problem fixed on Tuesday of last week with a new fan assembly.
    Jul 2016
    Michigan
    Thanks for the fast response bluerauder. Can I post videos on here?
    Not directly. I believe that you must post the video to a host site like YouTube and then provide a link to the video.
    Quote Originally Posted by Bluerauder View Post
    After its posted on YouTube, using the tapatalk app makes it a simple one button operation to post here if your using a smart phone.
    Mar 2006
    Maple Valley, WA
    Quote Originally Posted by WPG_Merc View Post
    Could it be a Timing Chain Tensioner Failure.
    Is the noise coming from the front middle of the head.
    I had that same noise on the passenger side.& found a Tensioner Failure & loose chain.
    ^^^^^^^ this right here
    Former owner of a 2004 DTR MM
    Jul 2016
    Michigan
    Here's a short video of the sound
    https://youtu.be/tMhLgM0D-X8
    Jun 2016
    Pontiac mi
    Timing chain guides and tensioners get kit from ebay and replace all chains and guides if you order of ebay kits 230 buck dont shop at auto parts they' over priced all parts
    It could be the starter too
    Does it stop making that noise if you start it, shut it off, and restart it?
    Jul 2016
    Michigan
    It's random. Sometimes it rattles and sometimes it doesn't. It also rattles while driving, but sometimes it only rattles at startup. It's pretty random
    I've had the starter rattle and it is not half as hair-raising as what I just heard. Look at the timing chain bud!...
    Sent from my SM-G900V using Tapatalk
    Aug 2007
    INDIANAPOLIS
    Question UNDERCARRIAGE RATTLE Issues
    I'm experiencing rattles of the undercarriage. The first item is inspected was the cross member, shocks, struts,stablizers and exhaust. When I drive over where the road is rough it's the most noticeable. I ask the dealer's mechanic in Plainfield about it and he replied not to be concerned about it. I'm the type of guy who hates any rattle and determined to locate and correct the annoyance or distraction. I've heard of converters rattling but I'll have to check them again. My last Mercury Cougar the converters rattled only when I started the engine, which I've not heard on the 03 Marauder. Any other items that I may have overlooked? Your input is greatly appreciated.
    Thanks!
    Fairlaner
    Since this thread is about engine rattles, you may want to start a separate thread about your undercarriage issues.
    Jul 2016
    Michigan
    Quote Originally Posted by TJCOX View Post
    Thanks!
    Fairlaner
    Post a video of the noise on YouTube, then put the link on your thread. Good luck man
  1. engine rattling when accelerating
    By ddog1216 in forum Shop Talk
    Last Post: 02-06-2015, 05:19 AM
  2. engine start rattling
    Last Post: 02-01-2015, 09:12 AM
  3. front engine cover
    By mercuryed in forum The Lounge
    Last Post: 06-30-2011, 07:54 PM
  4. rattling noise front end drivers side while going over bumps
    By computertech in forum Steering, Suspension & Brakes
    Last Post: 04-16-2011, 06:49 PM
  5. Engine Front Cover
    By usamusl in forum Capital Area Marauders
    Last Post: 03-29-2007, 11:25 AM
