Page 1 of 6 123456 LastLast
Results 1 to 15 of 76
Thread: Parts List to do your Timing Chain Guides/Tensioners
    So many people order the wrong or low quality stuff, so here is the best of the best to get the job done:
    Ford Parts:
    1R3Z-6L253-BA Right Arm
    1R3Z-6L253-AA Left Arm
    1R3Z-6M256-AA Left Guide
    2C5Z-6K297-AA Right Guide
    Remaining parts you can get from Rock Auto in one purchase:
    Cloyes 95338 Left Steel Tensioner
    Cloyes 95339 Right Steel Tensioner
    FelPro VS50477R Cam Cover gasket set
    FelPro TCS45980 Timing cover Gasket set w/crank seal
    If your car has high mileage, you should inspect the upper manifold gasket before re-installing.
    Excellent info! Making this a sticky...
    Ford Parts:
    Zack, are the tensioners the "better" ones?
    Pa
    Its the steel one so yes, though it is what are cars come with. So i guess its really just not down grading
    If it's cheap and reliable it isn't fast
    If it's cheap and fast it isn't reliable
    If it's fast and reliable it isn't cheap
    Many Marauders came with plastic tensioners, mainly in 04
    May 2009
    Moreau Island
    What about the Ford racing kit I see? Part #M-6004-A464. It has what you posted plus pretty much everything else.
    Oct 2008
    Toronto, ON
    Misplaced reply
    Last edited by GetMeMyStogie; 11-17-2016 at 07:39 PM. Reason: Meant to reply to OP
    Oct 2008
    Toronto, ON
    Is there a reason this list excludes the chains and gears (but includes the necessary gaskets)?
    I mean, is it because you simply get them from Ford, or is it because they don't actually need replacing if you change the guides and tensioners?
    Last edited by GetMeMyStogie; 11-17-2016 at 07:57 PM. Reason: Clarified question at risk of sounding silly
    Quote Originally Posted by GetMeMyStogie View Post
    Unless your engine has been neglected, those items don't wear out.
    Not any of the ones I've seen at least
    Aug 2007
    Du Page County, IL
    I might be pulling the timing cover to repair an oil leak onto the belt (verifying leak location first). Sounds like while I have it apart it wouldn't hurt to grab these parts and swap them out.
    "Beast, Jr."
    2003 300 A, 4.10:1 gear, JLT CAI, Marty tune, Nitto 420S and 555 tires, NGK TR55 plugs, J-mod, Skull lock knobs, and a new windshield
    Jun 2008
    Quote Originally Posted by ledzilla View Post
    Did you check your oil filter adaptor? The gasket is a known failure item.
    Jul 2011
    Upper Marlboro
    Yes they did ,and that what was broke on mine. Rock auto dropped the ball on the driver side guide ,it was for a 2 valve motor.
    Roger that
    Assembled 8/25/03. In service 11/5/03.[Safford Lincoln Mercury] . Returned from Service to Dundalk Lincoln Mercury 7/12/11 Adopted and reassigned to Street Duty 7/29/11 .at Car Center [Waldorf Ford] /Waldorf MD. # 27 of 997 silver burch #103 of 3214 Sold Oct 17, 2015. Replaced with 2016 XLT Explorer with 3:66 gear 4WD [ interceptor package] In addition 2015 -V6 Mustang added to the corral April 17,2015 with Roush upgrades .February 2018 upgraded to Explorer Sport , Ford blue ,intake upgrade, intake mod, Unleashed super tune, Governor removed. 1969 Mark III ,Forest Green still in fleet. Carlisle favorite .
    Aug 2007
    Du Page County, IL
    Quote Originally Posted by a_d_a_m View Post
    Oil filter adapter? Don't have one installed. Oil filter port is still stock, no adapters or anything for oil cooling. Plus, the leak looks to be coming from the other side of the motor, anyway. But like I said, going to have it inspected. I've been too busy working on my other cars to have time to properly check it myself.
    "Beast, Jr."
    He meant the factory oil filter housing gasket. Makes for a nice leak on the drivers side
    Jun 2008
    Yep, I knew I had the name wrong!
