It was a lot of work, but I am proud of it and I can honestly say I did as perfect of a job as I can. I am going to try to do another in a couple weeks when my hand stops shaking and my dremel cools off.
Marauderless!
how much did you actually hog out?
How are you preventing the metal from getting into the valves?
2003 MERCURY MARAUDER 300A
Build Date
5/31/02
Sequence#
#363 of 7839 Black Marauders
Dyno tested power
Best 1/4 mile time to date
12.456@109mph
Visit my Garage
Blackened300a's Garage
didnt even notice the pic of the heads. thats a good question Paul
Had a towel down in there and shop vac'd it all out as i went
Marauderless!
Nice looking port job! Did you use a pneumatic die grinder or a Dremel tool?
When I port matched my heads to my extrude-honed intake & port matched hard plastic intake manifold gaskets, I did the same thing.
Stuffed a towel down each port and then put 2 layers of masking tape on top of that.
When I was done, I vacuumed out all the metal shavings from on top of the tape.
Pulled that layer of tape and vacuumed again.
No more metal shavings!
(Though...It was pretty scary doing it!...)
I used a Dremel 4000
Marauderless!
