Results 1 to 15 of 22
Thread: EGR Valve Block-off Plate
    Jul 2014
    dubuque , I.A.
    i was looking for an EGR Block off Plate kit, for a MM,s. If u can give me the brand an Part Number , Thanks..
    I was not sure one EGR Block of Plate kit for 4.6 4 valve for Mach 1 or Cobra would work on MM. Intakes !?!?
    Apr 2010
    South Florida
    JC Customs CNC.
    Oct 2008
    Massachusetts
    Quote Originally Posted by mercuryguy View Post
    The Cobra/Mach one plate fits fine, I have the Jegs plate on my Marauder.
    Oct 2003
    Beaufort, SC
    Why delete the EGR system??
    Jun 2008
    Waukesha, WI
    Cause it’s ugly
    Oct 2003
    Beaufort, SC
    But it does good things......when working right!!
    Jul 2014
    dubuque , I.A.
    thanks for the info Guys!! i went an just bought Jeg,s EGR. block of plate for 4.6 4 Valve engines...
    Feb 2018
    Saudi Arabia
    I blocked it off and I wished I didn't, keep everything connected and turn it off with a tune.
    Jan 2017
    Regina, Saskatchewan Canada
    Ok I’m curious why you blocked off the egr and regret it now? I’m just trying to understand why some builds delete it and others keep it.
    I turned mine off in the tune, and deleted it.
    Trilogy # 192 / T.S. 0012
    Oct 2003
    Beaufort, SC
    When working properly the EGR system cools combustion temperatures and aids in complete combustion at part throttle!!
    Above 3/4 throttle (low intake vacuum) it is turned OFF and has no effect on performance!!
    When not functioning properly it can cause drivability problems!!
    The Dirty South
    All true... Introducing NOX into the combustion chamber does have benefits for cooling the combustion chamber.
    It also dumps a lot of soot and fuel deposits into the intake track. If your running a centri or turbo no big deal but if your running a PD I can see the need to delete it.
    I deleted mine since the Trilogy
    Quote Originally Posted by Shinker View Post
    I deleted mine simply to clean up the engine bay plus it was pretty much the last emission part left besides cats.
    I don’t care for the stink from breathers however. I ended up adding a breather tank that I drain out maybe twice a year. Mounting down low on the frame certainly helped with the stink but it didn’t rid all of it.
    I may go back to the EGR someday. I’ll just re route it somehow so it’s out of sight.
    I made my own block off plate/fuel regulator holder out of aluminum L channel cut and polished to fit.
    Jul 2011
    Bay Area, CA
    deleted mine and noticed a significant decrease in fuel economy along with smells much worse... I will be adding EGR back when I can. thats my 2 pennies
    98 P71 SOLD
    Apr 2010
    South Florida
    Quote Originally Posted by Chayton View Post
    I get more smiles per gallon, and never noticed a smell change. Only difference is the car doesn't rev crazy on cold start.
  1. Wanted To Buy 4r70w valve body plate and gasket
    By Bob Mathis in forum Marauder Parts/Misc. Wanted
    Last Post: 07-18-2015, 05:10 AM
  2. Wanted To Buy Coil engine valve cover plate
    By Guittard22 in forum Other Parts/Misc. Wanted
    Last Post: 10-09-2012, 07:28 AM
  3. Short Block or Long Block, or Parts & Pieces
    By FordNut in forum Marauder-specific Parts for Sale
    Last Post: 08-25-2009, 06:29 AM
  4. Top plate on valve covers??
    By Merc-O-matic in forum Shop Talk
    Last Post: 05-12-2005, 07:39 PM
  5. In Tech 32 valve V8 Plate on a 04 MM ???
    By Black 04 in forum Community Discussion
    Last Post: 03-17-2004, 05:40 AM
