How many speeds does the electric fan for a 2003 marauder have? If it has 2 when does second speed suppose to kick in?
Sent from my LG-H918 using Tapatalk
Stock programming turns low on before 200. High is 210.
When AC is on, I believe it’s on high full time when the compressor clutch is engaged
W
If turn the key to on without turning the car on does the fan suppose to kick in?
Key on one speed. When I turn on AC second speed. Is that all the speed it gives?
I think my fan is working fine. The reason I'm asking is cause the car started overheating. I already changed the thermostat and water pump. Last night while checking. I noticed the heating gauge was passing halfway looking to overheat the upper water hose extremely hot to touch bottom hose and radiator almost cold to touch
Google 4.6 dohc burping procedure or go to Reische Performance
I couldn't make the water flow. I burp it with heater on till only coolant came out from crossover screw. The coolant drain because it was starting to overheat. Top hoses extremely hot with pressure while bottom hose cold to touch. Temperature reached 214f. Got tired and removed the thermostat and water flow to all hoses. Would that be a problem? Where I live it's extremely hot all year round. Maybe 1 to 2 months of winter but it only drop to 40s
the maraduers does not have a dual speed fan. They have a variable speed fan. Anywhere from 0 to 100% (2 to 29 commanded in the tune)
speed increases with increasing coolant temperature
when my fan went out on my 03 I tossed a brand new 2018 mustang fan on it since it was the only fan I had laying around.
Yes correct thermostat and installed correctly.
You still have air in system,
