Does anyone happen to know that part number for these studs? Or does anyone happen to have a set laying around that i can buy. TIA
1.1999 P71 stock
2.2003 Marauder 300A Mods: JLT intake MSD coils SCT livewire TS with custom Mo's tune
Have you removed the nuts yet? If not, it’s all reusable despite what people say
1.1999 P71 stock
Ex Panther Owner
When I did mine I fiddled with it for hours and got nowhere......ordered new studs and never broke the bottom part off....just in case!!
What a PITA and the electrical plug over the tank by the passenger side rear wheel.......UGH!!
Cut wires, add weather pack connector.
I drilled out the trunk sheet metal (above the stud) with a hole saw and installed a (long enough) stainless steel bolt to easily connect the strap. Plugged the hole with a expanding rubber plug (as used for freeze plug replacements).
ΓρεεκΓοδ
