Results 1 to 15 of 16
Thread: Need some torque spec help please
    Wisconsin
    Need some help. I'm doing my Cobra intake cam swap. According to the 2003 Mercury service manual (see attached pic) the 4V cam cluster cap is torqued to 14ftlbs. I've been cruising the internet looking for cam gear bolt torque for 98 Cobra motor as the bolt is significantly larger than the OEM Marauder bolt and keep coming across cam cluster cap torque listings of 7.5ftlb. Which is correct?
    Thanks!
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    Legacy 600w 6x9 Rears
    JL 6.5 SubWoofer
    DR Deep Aluminum Trans Pan
    Mo's Dyno Tune
    Gorilla Nuts - The System
    Maryland
    Do you mean the cam sprocket bolt?
    601rwhp 592rwtq @19psi
    Maryland
    Thanks!
    sorry re read it.. I used the marauders specs for the cam hold downs, and I used arp for the cam gears which came with their own torque spec, I wanna say it was 100 ftlbs dont hold me to.it tho, yes the 98 cams to have a larger bolt
    Maryland
    Looks like 82-92 ft lbs is what they 98 cam bolts are torqued to
    Jul 2014
    NY
    Wisconsin
    Quote Originally Posted by Seneca View Post
    The 14ftlb is a Marauder spec, right out of the Ford book. I'm starting to believe this is an error on the book. This is my dilemma.
    Going to check with my client that is a Ford tech to get correct number.
    Thanks
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    JL 6.5 SubWoofer
    Mo's Dyno Tune
    Wisconsin
    Thanks, I kept finding these too but there is a lot of variance in numbers so wanted to check with the mm.net MM experts.
    I am consistently finding 76-106inlbs or 90inlbs for the cam caps so it's looking like the Ford manual is wrong...
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    JL 6.5 SubWoofer
    Mo's Dyno Tune
    I only use Alldata and mine have held up fine at 14 ft lbs. I don’t recall using any other source. Best to confirm with your friend. I think I have a set of caps if you fudge them up!
    I remember it being kinda scary..
    Wisconsin
    Thanks Bob.
    Already torqued driver side to 14ftlbs and then finding the bigger cam gear bolt sent me looking for torque spec.
    Confirmed with Marty the 71-106 in. lbs. spec is correct. Caps didn't crack so will loosen & re-torque to correct number as advised after Checking with Troy for double confirmation.
    I love this community...
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    JL 6.5 SubWoofer
    Mo's Dyno Tune
    I’m sure it’s fine. Just think how many tens of thousands out there just between Ford’s and Alldata’s specs have been done!
    May 2009
    Moreau Island
    If your friend is a Ford tech he can check if there was a TSB on the spec in the MM book.
    Wisconsin
    I checked in at my local Ford dealer and Nico the parts guru looked it up on their online db and we found it currently lists 89inlbs.
    So, everyone online & Marty are correct.
    The 2003 Ford service manual is wrong.
    Thank you all for everything!
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    JL 6.5 SubWoofer
    Mo's Dyno Tune
    Jun 2008
    Waukesha, WI
    Nico knows his stuff! Way more than the average parts guy.
    Wisconsin
    You know the Nico? He lives just up the road from me.
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    JL 6.5 SubWoofer
    Mo's Dyno Tune
    Jun 2008
    Waukesha, WI
    Yeah. Mutual friend
  1. Torque spec for Baer rotors?
    By blazen71 in forum Steering, Suspension & Brakes
    Last Post: 06-19-2010, 01:06 PM
  2. Torque spec?
    By Local Boy in forum Innovative Interceptors
    Last Post: 04-03-2009, 11:19 AM
  3. Flywheel Torque Spec
    By Blackmobile in forum Shop Talk
    Last Post: 08-29-2008, 06:54 PM
  4. Spark Plug Torque spec
    By ctrlraven in forum Shop Talk
    Last Post: 06-30-2007, 11:10 AM
  5. Lug nut torque spec and size....
    By junehhan in forum Shop Talk
    Last Post: 06-01-2004, 03:30 AM
