I recently brought a Teskid block for rebuild and realized that hose for Knock sensors is bigger that marauder block. What can I do here?
Bolt the sensor to the back of the head
Trilogy #167
Teksid block
Manley H beam Rods
Mahle pistons
Forged crank
3.0" pulley
factory exhuast
Dyno: 436.99 HP 437.81 TQ
Best et 12.823 (w/ a lot of spin)
Best mph in 1/4m 115
Throw it in the garbage, since it does nothing.
Marauder gained a second knock sensor for the ’04 model year. Some insight into what a ‘knock sensor’ does (for those who don’t know):
Autopartswarehouse.com adds that a defective knock sensor does not properly adjust the timing of the engine when fuel enters the cylinder. This causes the vehicle to lose fuel mileage and acceleration. Additionally, a bad knock sensor causes irreparable damage to the engine. According to Repairpal.com, the knock sensor detects vibrations and transmits data to the engine computer. These vibrations or engine noises are caused by detonation.
When the knock sensor is damaged or broken, the detonation process is not regulated properly. Autopartswarehouse.com explains bad knock sensors also lead to excess engine noise. These noises are generally loud thumps and are a result of air or fuel entering the cylinder. Autopartswarehouse.com recommends identifying the symptoms of a bad knock sensor and replacing the part immediately. A new knock sensor helps avoid damage to the engine and eliminates costly repairs.
https://www.reference.com/vehicles/s...577d9e0b00403a
Current Garage:
2005 Mustang GT Premium
2015 Triumph Trophy SE
― William W. Purkey
with a PD blower a knock sensor is useless.
You want knock protection get a Vampire knock controller.....
I disagree. The marauder knock sensor works excellent when tuned properly.
This is a must read.
http://forum.efidynotuning.com/viewt...hp?f=18&t=2418
Listen to Zack. He knows what he's talking about...
https://www.mercurymarauder.net/foru...ad.php?t=96526
https://www.mercurymarauder.net/foru...ad.php?t=28388
Current Garage:
― William W. Purkey
Current Garage:
― William W. Purkey
