Page 1 of 3 123 LastLast
Results 1 to 15 of 32
Thread: Sway Bar + Control Arms + Watts Link + Tires + Alignment = WOW
    Jul 2003
    Virgo Super Cluster
    So I got new tires this week along with a balance and alignment. Just a couple of weeks ago I had control arms and watts link installed. Last year, a rear anti-sway bar.
    I took a couple of corners today faster and with less "mechanical protest" than ever before. How does something this size do that?
    Once I have the front end taken care of, I am pretty sure I won't have to brake for corners.
    Dave
    San Diego
    Concur!
    Concur, I have upgraded sway bars, control arms, watts link, performance tires, all wheel alignment, and the widened rear wheels don't hurt either. -kjs-
    Weatogue, CT
    Dido on the upgrades
    Quote Originally Posted by NAVCHAP
    Since doing these upgrades, the MM 300A handles great. But after installing the frount sway bar I did start feeling a little steering wheel jitters around 38 mph. It goes away around corners and at higher sppeds - good thing for that. So I'm planning on doing new tires and wheel alignments in the spring.
    Anyway it's time to put on the snow tires, it snowed today about 2".
    George G
    As much as we love technology, we must be prepared for the inevitable, it fails.
    Motor City
    You should consider next upgrading the axles. They're like overcooked pieces of asparagus. They flex alot through corners.
    Central NJ
    Quote Originally Posted by Warpath
    Upgrade with what? A 31 spline axle or something custom? I can always use another way to spend more money on my baby.
    2001 Grand Marquis w/HPP
    BC4E Dead Pedal - Ford Billet Fuel Door - Mufflex custom 2.5" Manifold-back exhaust w/X-Pipe - Meg's 4" Marauder Tips - Metco Rear Control Arms & Watts Link - Reinhart Fuel Filter Mod - Quickor Swaybars - PST Carbon Fiber Driveshaft - Dyno Pro Panther Door Sills - BF Goodrich KDW-2 245/40/19 Fronts & 285/35/19 Rears - H&R Spacers 30mm & 35MM - HP Design EVO 19x8.5 & 19x9.5 Wheels - Zexel Torsen T2-R Differential - Ford 3.73 Gears - DG Motorsports Radiator Cover - PSP tuned Excal 2 - Ford Silicone Coolant Hoses - QA1 Dual Adjustable Shocks - Car Motorsports Panther Logo UH & TL Liners - TA Performance Differential Cover - Magnaflow Cats & Mufflers - Accufab 75mm Plenum & Throttle Body - 1" Throttle Body & 1/2" Intake Spacers - AP Racing 6 Piston/13.5" Rotors Front Brake Kit - 4" CAI - Typhoon Intake Manifold - EMP Stewart Water Pump
    SuperMotors Page
    CJMF
    MotorSports North East
    15.195 @ 89.79 - 2.207 60' - 4458 lbs.
    Quote Originally Posted by BK_GrandMarquis
    Go ahead and have a custom 9" fabricated!
    Hiram, Georgia
    That's what I did on Hell Boy!!
    Forget the axles...you need THESE!!!! Just ask anyone who's driven my car in the last couple of days....WOW!!!
    Hiram, Georgia
    ^^^^ Yep, Todd has the best dialed in MM that I have ever driven!!!
    Did you upgrade the axles...or the whole rear end assembly??
    I've talked to DTS (Drive Train Specialists) and Mark Williams Enterprises and both will take your MM 8.8" Rear end and perform the following:
    -weld axle tubes to the center section
    -install 31 spline axles
    -install your choice of gear ratio
    -install Eaton Posi
    -install steel 'main cap' on carrier (left side only as this is the side driven back on hard acceleration)
    -install ARP main cap studs
    -cut off OEM axle tube ends and weld on 9" ends with larger bearings (same bolt pattern as 8.8" axle ends and the 9" ends have a press fit bearing so the 'C-clips' are not needed)
    -install 1350 billet pinion yoke (Mark Wiliams Enterprises)
    I figure I'll drop the rear axle and do this mod all at once in conjunction with a S/C & Nittos
    Hiram, Georgia
    Did this
    Did this
    Did this with 4.10's
    -install Eaton Posi
    I went with the Auburn ECTED electric locker. When I am staging and before I burn out I electronically lock the rear and it is like having a spool. So far this has worked well for me and I think it is cool
    Did thison both sides
    Did this
    I have read about this, but did not do it. It is a good idea though.
    Did not do this but it is a good idea for sure. I may go back and do this.
    Joe...specific answers for Marty's car are in RED
    -weld axle tubes to the center section YES
    -install 31 spline axles YES (custom from Moser engineering)
    -install your choice of gear ratio YES
    -install Eaton Posi NOPE (Auburn Gear ECTED electronic locking differential custom built for 31 spline)
    -install steel 'main cap' on carrier (left side only as this is the side driven back on hard acceleration) YES
    -install ARP main cap studs YES
    -cut off OEM axle tube ends and weld on 9" ends with larger bearings (same bolt pattern as 8.8" axle ends and the 9" ends have a press fit bearing so the 'C-clips' are not needed) NOPE, not necessary with our setup
    -install 1350 billet pinion yoke (Mark Wiliams Enterprises) Nope
    I guess SICK minds, think alike?
    Hiram, Georgia
    ^^^^ Is there an echo in here???
    Thanks...Looks like you've got a bullet-proof rear end assembly....definitely needed if you are pushing 666 through it!!!!
    (Or is it MORE than 666 now???)
  1. control arms & watts link special
    By Metco in forum Community Discussion
    Last Post: 10-13-2004, 12:38 PM
  2. Replies: 12
    Last Post: 05-03-2004, 01:28 AM
