Results 1 to 15 of 21
Thread: Rear quarter panels warped
    Jan 2005
    Just South of Memphis, TN
    Unhappy Rear quarter panels warped
    Yes, I know we've covered this before...
    Now both sides of my Marauder are warped out of shape...just behind rear wheels...
    I can't seem to find the right phrase for the "search"...
    Anybody remember or have a suggestion...?
    Seems like somebody glued styrofoam in behind theirs...
    Thanks, Architect
    "Ford Racing" 410 gear
    18"X8.5" Black Bullitt Wheels
    "Ford Racing" Center caps
    Black Wilwood Brakes (fronts)
    "Powered By Ford" coil covers
    30% Window Tint
    "X-pel" Light Shields
    "Pro-gard" skid plate
    Rear Spoiler
    "Kenny Brown" dead pedal
    "Megs" delete resonator tips
    "SS" Titanium Inserts
    Blacked out window trim
    Blog Entries
    2
    On the MM's I have seen you really have to get at the right angle and lighting to see it.
    Is that the case, any pics?
    Oct 2006
    Jackson TN
    got it too
    i have it too on both sides...what i did was wedge styrofoam behind bumper cover on both sides from underneath the car...i just used different size pieces to accomplish a un-warped look...been in there for 6 months now with no movement
    03 300A / 08-15-02 Build / #3525
    Gone But Not Forgotten
    03 SVT F-150 / 05-01-03 Build / #3553
    Lots Of Mods..13.5# boost
    04 SVT Cobra
    2.9 Whipple
    03 Harley F150
    Stock Boost...For Now
    Jan 2005
    Quote Originally Posted by gmtech View Post
    You the styrofoam man...
    I just took a closer look and I can see where there is an inner panel and the outer fender panel...so something could be placed in this space to push out and hold the fender in proper place...possibly glued into place...
    Thanks for the information...I'll do a little more research and if I come up with something that works well, I'll post it back here...
    Thanks again, Architect
    30% Window Tint
    Rear Spoiler
    Oct 2006
    Jackson TN
    Quote Originally Posted by Architect View Post
    exactly..i just removed the screws holding the bumper cover to the frame on the underside behind the whelels..and then placed the stryofaom back there and reinstall screws..looks great ..hardly noticeable unlike before..could see it from a mile away...
    04 SVT Cobra
    2.9 Whipple
    03 Harley F150
    Lawrence Twp., NJ
    A proguard will help "sure it up"
    Member # 383.
    2003 Marauder Black.
    Build 8/13/02
    Launched 9/28/02
    Sold May 16, 2018
    #3,646 of 7,839 black '03
    Long Island, NY
    What Jim said. ^^^^^
    2003 Marauder 300B,
    Heated Seats
    35% Tint
    Mercury All Weather Mats
    1973 Oldsmobile Toronado
    2012 Kia Sedona Van
    2008 Corvette Convertible
    2021 Prius Prime Limited
    Member # 440
    ----- John
    Dec 2005
    Layton, UT
    A body issue? On these cars??? noooooo......
    For what its worth I have a proguard and my back bumper is starting to warp/sag a hair even with it. Without the proguard that bumper would be draggin pavement. Proguards should of been a STOCK item.
    Matt H.
    (sold)2004' SB, 268rwhp/295tq
    2017 F-150, 5.0
    2013 SHO DIB Performance Pack
    Lawrence Twp., NJ
    It is a bumper sag, there is a way to fix it under the bumper in the middle.
    Member # 383.
    Build 8/13/02
    Launched 9/28/02
    Sold May 16, 2018
    Both of mine have the bowing of the bumper cover behind the rear wheels below the quarter panels. A foam insert may be a good idea, if it doesn't hold moisture and cause the quarter panels to rust.
    NY
    Yea, I have the same problem as described, I can see mine from quite a distance and when the light shines on it the right way it just looks terrible, almost like the car has been hit...
    Reinhart tune, NGK TR6 Plugs, 180 Degree stat,EMP/ Stewart Water Pump, K&N Aircharger, Cobra Exhaust, Megs Delete Tips, Flowmaster 40 Series Delta Flows, 4.10 gears, COP Connectors, Underdrive Pulleys, PHP Intake Spacer, 255/55/18 KDW2 Rears, Powerslot Rotors, Hawk Pads, TCI Deep Trans Pan, Ford Racing Girdle
    Lawrence Twp., NJ
    The trick is the middle of the bumper. If you stand back and someone gently pull up on the bumper you will see the the sag disappear.
    I forget how I corrected this as the car is put away for the winter so I can not look. It is not hard to fix
    I will post up with pictures in the srping
    Member # 383.
    Build 8/13/02
    Launched 9/28/02
    Sold May 16, 2018
    Jim, are you talking about the back of the bumper cover or the sides? The earlier comments about the ProGard helping would be true if it is at the back of the bumper, but this issue is on the sides of the car. I have ProGard's on both of my cars and they still have the bowing in of the bumper covers behind the back wheels.
    NY
    I think somebody should make an aftermarket rear bumper made of beefier plastic. Ship them painted to match and if it was with in reason id definately buy one. The plastic the bumpers are made out of is really crappy cheap ***** to say the least.
    Lawrence Twp., NJ
    Pro Gaurd will help the sides a little, issues is size of the bumper and lack of clips under there it hold it. I am too lazy to pull mine out till spring and look under there is see what my buddy did to correct it. My issue is the back bumper has been repainted/replaced twice now. Insurance Companys love sending me $2,000. checks to fix it
    Member # 383.
    Build 8/13/02
    Launched 9/28/02
    Sold May 16, 2018
  1. warped rear fender panels
    By Architect in forum Shop Talk
    Last Post: 10-22-2007, 07:35 PM
  2. Rear Load leveling - possible issue
    By Rkammer in forum Shop Talk
    Last Post: 07-12-2005, 11:01 PM
  3. Popping from rear suspension diagnosed
    Last Post: 06-09-2003, 04:04 PM
  4. Check the rear ends.
    By tomd in forum Shop Talk
    Last Post: 04-23-2003, 08:49 AM
  5. Rear Spoiler's Air Flow Impact?
    By WJSOLOMON in forum Community Discussion
    Last Post: 10-13-2002, 12:40 PM
