Page 1 of 4 1234 LastLast
Results 1 to 15 of 51
Thread: Kook's Headers Dyno Results!!
    Mar 2002
    Round Rock, TX
    Talking Kook's Headers Dyno Results!!
    Wow!
    I just got back from doing the post-dyno on my car with the Kook's exhaust on and was so excited I just can't contain myself!
    Wow! (It bears repeating)
    The only caveat I have to mention is that my car has a 3000rpm stall in it, so getting number much below 4000rpm is near impossible on a dyno. BUT, I can tell you, the newly available amount of power and torque down low launches my car like you wouldn't believe out of the hole.
    That being said, my car prior to the header install, was making 256.3rwhp and 278.6rwtq.
    My car, post header install is now making....
    285.7rwhp and 293.5rwtq!!
    That's peak, 29hp and 15tq!!
    What's important to examine is that although the peak numbers are high, there are even higher spreads in the torque and power bands throughout the curve. There's almost a 50hp spread on power at 6000rpm!!!
    All in all, what a kick ass investment!!
    nick filippides Guest
    Logan, Im real happy to hear great news. Much like the 4V Mark VIII, the headers made a huge difference. 29hp at the wheels is more like 45-50hp at the crank. I'm estimating 3-4tenths drop in et and 2-3mph increase at the track. Logan I'll bet dollars to donuts that your gas mileage will improve as well. Thanks for your help. Nick "Kook's Headers"
    Blog Entries
    2
    Woooooow!
    Thanks for posting the info.
    Let us know about the install, how difficult? Can an occasional wrench turner master it?
    Any welding, air wrenches or special tools required?
    Los Angeles - California
    Good going Logan.
    Can you post a pic of your engine with the headers?
    Also, how long did they take you to install?
    2004 BLACK MERCURY MARAUDER
    SCT
    JLT Cold Air Induction
    PHP Intake Spacer
    Cobra Ported Manifolds
    Flowmaster 50's
    Magnaflow X-Pipe
    Stallion TC
    4:10's
    Steeda Underdrive Pulleys
    Rear sway bar
    1969 GREEN MACH I MUSTANG GT
    351 Windsor
    Shelby Cam
    Shelby Tri-Y headers
    Ported and polished heads
    10.5:1 Domed pistons/rods
    Balanced and blue-printed
    Offenhauser Intake
    NOS plummed under intake (8 fuel injectors, 8 NOS injectors)
    Art Carr TC
    Tranny shift kit
    Dual ignition with MSD
    3:90 Posi rear end
    Bought car when I was 16 and still have it
    Mar 2002
    Round Rock, TX
    Patience... I'm writing up the full report, with pics. It'll be up on Thursday.
    I will say in advance though that I'd recommend they be installed by a competent shop. From the time we pulled the car in, to the time we pulled it out including welding up an entire exhaust system was about 12 hours labor. About 8 hours on install, 4 on welding, pipe bending and exhaust assembly.
    If you give the installer a copy of the review I'm working on, he should be able to save himself a couple hours by not having to relearn the install.
    Jul 2002
    Richmond, VA
    Logan,
    Awsome numbers I'm just pissed I didn't get a ride. Thanks for a great weekend
    John
    2003-300A
    Trilogy #8 with Custom Pulley Produces 12.4psi of Boost
    407 RWHP and 384 RWT
    Best 1/4 Mile 12.028 @ 117.01mph
    From Lidio: Trilogy #8 install & Custom Tune, Custom Pulley, Chip, Accufab Throttle Body, Baer Claw Front Calipers with Crossdrilled & Slotted Rotors All Around, Custom 2¼ X-Pipe, 3 Chamber Flomaster Mufflers, Widened Rear Rims with 305 Nitto NT-555R Extreme Drag Radials, Auburn High Performance Posi.
    From Reinhart: 4.10 Rear Gear, 180 Degree Thermostat, Motorcraft Plugs, Metal Matrix Driveshaft, Rear Sway Bar.
    From Metco: Carbon Fiber Intake Tube, Control Arms & Watts Link.
    From Others: Kenny Brown Braided Brake Lines & Dead Pedal
    Jul 2002
    Southern California
    We can't pass smog here in California with those, can we?
    2003 Mercury Marauder
    2007 Mercury Mariner Premier 4WD V6
    2008 Mercury Sable Premier
    2002 Mercury Sable LS (Sold)
    1998 Ford Contour Sport (Sold)
    1997 Mercury Cougar XR7 (Scrapped)
    1997 Mercury Villager Nautica (Sold)
    2003 Mazda Protege5 (Sold)
    Mar 2002
    Round Rock, TX
    Not sure if Kook's has a Carb number on them, give them a shout and ask.
    That's more like it! For so long all we heard was "headers will not help produce power in a NA MM". Just been anxiously waiting for somebody to prove it. Thanks. (I think... now that's more money I gotta spend).
    BTW, I got a quote on a Bassani SS x-pipe. It looks sweet and costs less. I'm thinking of trying the Kooks/Bassani combo. So many possibilities!
    Mar 2002
    Round Rock, TX
    I'll just say that the Kook's X is worth every penny. It may not be "pretty" as the bassani unit, but having had both, I'll say the Kook's unit is technically superior. They put ALOT of manual handiwork into the interior of the Kook's X.
    I wish I took pictures of the inside of the kook's X... Seeing is believing.
    Long Island, NY
    Headers
    Logan - Thanks for the report. Waiting to see pix.
    2003 Marauder 300B,
    Heated Seats
    35% Tint
    Mercury All Weather Mats
    1973 Oldsmobile Toronado
    2012 Kia Sedona Van
    2008 Corvette Convertible
    2021 Prius Prime Limited
    Member # 440
    ----- John
    Mar 2003
    Los Angeles
    WOW, LOGAN! THOSE NUMBERS/CURVES ARE AMAZING!!! Yeah--"ditto" what FordNut said!!! I know you're busy writing the full report (and thank you for doing that), but as to the factory cats, did you replace two/delete two, or did you replace all four factory cats with the Magnaflow high-flow cats? Us California guys want/need/deserve that kind of header performance, too! Your exhaust MUST'VE gotten LOUDER and BEEFIER sounding too, right?!?!?!? In fact, the damn thing must have a screamin' ROAR to it now, eh? Which mufflers did you have again? Incredible post, Logan!!! Incredible!
    Mar 2002
    Round Rock, TX
    I believe the secondary units are simply resonators, not convertors. I went with two High Flow Magnaflow Cats, and welded the secondary O2 sensors right behind them, no codes have popped, so it must be working just fine.
    Apr 2003
    Jersey Shore
    AAGGHHH!!! I can't wait to get mine installed!! Yippeeee!!!
    '03 300b - all the bolt-ons (SOLD)
    '93 Mustang Notch - restored w/ all the bolt-ons (SOLD)
    '97 F350 Powerstroke 5 spd, 4" straight pipe, 5" stacks, Rockford system, 35" tires...(SOLD)
    '95 Lightning - bolt-ons and susp (Totalled)
    '93 Stang Notch - full resto with autocross susp (SOLD)
    '01 Lightning - 3"/4" drop and full bolt-ons... FAST.
    Mar 2003
    Los Angeles
    Well, Logan, that sounds damn fine to me, then. Aww, to Hell with passing California emissions . . . I've got four years on a new car until I have to smog it, right? Damn, those Kook's headers and X-pipes got me all excited now . . . Just think how great the car's gonna run once you get a blower on there too! Can't wait to see your pics and descriptions of your install, Logan! Thanks for doing all the legwork on this one! And THANKS for getting us the club discounts from Kook's!
