Results 1 to 12 of 12
Thread: foglights
    Smyrna,Ga
    foglights
    foglights and how do you change them ...how do you get to them step by step please............
    Quote Originally Posted by bigmerc'03
    The bulbs or the whole assembly?
    The covers under the bumper are fastened on one side with velcro. Pop those loose and there ya go.
    Weatogue, CT
    Bright White Fog lights
    Any one know were I can get briight white flog lights? If you had the part number that would be great too.
    George G
    As much as we love technology, we must be prepared for the inevitable, it fails.
    Smyrna,Ga
    Quote Originally Posted by Rider90
    the whole assembly
    Smyrna,Ga
    Quote Originally Posted by TripleG
    Sylvania Silverstars H1 ST
    OK...I know you're not gonna like this....but...
    The owner's manual gives really good instructions on how to open up the fogs. READ!
    You can do this on your back, but it's easier if you jack up each side of the car as you go.
    One side is wide open, the other side requires removal of a velcro cover to gain access.
    There is a clip to open the rear of the fog light, and it will swing down for bulb access.
    You will see a metal diffuser cover over the bulbs. Many of us removed it. IT WILL NOT HARM ANYTHING TO REMOVE IT, and it will allow the light to cast broader at night. The diffuser is merely 'plugged' into the assembly and requires quite a tug to remove.
    As far as bulb replacement, replace with bulbs that match what you have in the headlights, otherwise the combo of all four looks wierd with different color casts at night.
    I used ZENON's which match my headlamps. I also upgraded the OEM 55W bulbs to 100W each. No trouble in 23 months. I ALWAYS run my fogs on overcast days.
    I get my ZENON's from JCWhitney mail order, and have had WONDERFULL experience with these bulbs. They are not prone to premature failure as the headlamps occationally do.
    2017 Niro
    Dec 2003
    You don't need to replace the whole assembly unless it is broken.
    If the bulb burned out....all you need to do is replace it.
    I emailed you Bigmerc.
    Silver 2004 Marauder
    Trilogy #48 (SOLD April 2014)
    1984 Mustang GT, stock, 60,000 original miles (SOLD August 2013)
    2017 Ram Rebel 1500, Silver: 5.7 Hemi, Lots of extras...
    Previous: 2014 Durango R/T
    Smyrna,Ga
    Quote Originally Posted by FiveO
    thank you for the info FiveO really helped me out
    Madison, WI
    Could you share that info with em as well? I'm having a hell of a time, replacing the fog light bulbs. Laying on my back, hand thru the flap, not being able to see anything, can't be the right thing to do.
    I also can't find anything in the manual about replacing the foglights.
    Help, please!
    TIA,
    Peter aka MMM2003
    300A Stock MM03 born on 6/25/2002 - sold June 2010!
    (owner from 8/26/2002 - June 2010)
    - Production# 2003 of 7838
    - @17000miles 1/4 in 15.1s@93.3mph
    - 180 TStat
    - 235/50/18 on all four corners
    - Dyno tune by SCT (Jerry W.) on 04-03-04
    @ 260.7 hp/285.5 ft-lbs
    - Front and rear EBC brakes with SS lines
    - PHP upper & lower rear control arms
    - Metco C/F intake tube
    - Infinity speakers
    Cape Cod
    Workshop Manual
    Fog lamp
    1. Raise and support the vehicle.
    2. Disconnect the electrical connector, remove the four (4) screws and the fog lamp assembly.
    3. To install, reverse the removal procedure.
    Fog Lamp Bulb
    2. Disconnect the electrical connector and remove the fog lamp.
    Madison, WI
    Thanks Bunny!
    Raising the vehilce made the difference. It helps if you can see what you are doing.
    Peter aka MMM2003
    - 180 TStat
    - Infinity speakers
  1. Ever replace your foglights?
    By FiveO in forum Shop Talk
    Last Post: 10-08-2004, 06:33 PM
