Results 1 to 8 of 8
Thread: Jet Car Marauder 1st Pass!
    Blog Entries
    2
    Talking Jet Car Marauder 1st Pass!
    Finally the Jet Car Marauder made it's first full pass!
    Oct 2003
    Beaufort, SC
    Well.......how'd it do??
    Isn't that Jet Marauder called the "April's Fool".....?
    Feb 2012
    harrison twp,mi
    Never gets old though....
    Those were the days.........
    DANG THEY'RE CUTE!!!!!!
    Smile and Nod
    I love THIS bar
    At first I thought that the picture was an OEM 4.6L engine with compromised head gaskets being fed high Boost and Nitrous !
    Blog Entries
    2
    Thanks for the Laughs!
    Oct 2003
    Beaufort, SC
    Same here!!
    Oct 2014
    Cunningham, Kansas
    And I thought he just needed new glasses, LOL.
  1. Replies: 27
    Last Post: 10-19-2016, 07:02 PM
  2. Wanted To Buy Need parts for wrecked marauder, Drivers side corner lamp, pass side headlight, +more
    By Turbov6Bryan in forum Marauder Parts/Misc. Wanted
    Last Post: 06-25-2016, 08:29 PM
  3. Marauder can't pass a VW?
    By pem in forum Community Discussion
    Last Post: 03-24-2012, 05:54 PM
  4. Marauder sits 3/4" lower in rear on drivers side than pass side. Adjustable??
    By Stranger in the Black Sedan in forum Shop Talk
    Last Post: 04-02-2007, 03:02 PM
  5. Wrong EZ-Pass for Marauder?
    By Flat Eric in forum Shop Talk
    Last Post: 05-20-2003, 10:09 AM
