Results 1 to 4 of 4
Thread: Center console armrest
    I've been looking for a MM center console armrest, but have not had any luck.
    I have never seen a Marauder in the local junkyards, and none of the CVs have been 'Sport' models.
    Anyone know where I might find a dark charcoal center console armrest?
    (I only need the padded armrest/lid, but will buy the entire console if I need to.)
    Timbuk3, MI
    If you can't find used .....
    Part # XF3Z-5406024-AAM - Black *a.k.a. Dark Charcoal
    $157 - retail / $116 - wholesale
    Quote Originally Posted by gdmjoe View Post
    Is that the entire console?....or just the padded armrest/lid?
    Timbuk3, MI
    Joe Walsh - Is that the entire console?....or just the padded armrest/lid?
    Ummmm ... You asked about the "padded armrest/lid" ... That's the part # that I provided - I do know the difference.
    *The parts list pic' shows that it includes the console guts under the armrest; i.e. the insert.
    EDIT: Parts List excerpt added.
  1. Replies: 4
    Last Post: 06-09-2008, 05:58 AM
  2. Marauder/CV sport center console wanted
    By RocketCouch in forum Marauder Parts/Misc. Wanted
    Last Post: 04-16-2008, 12:17 AM
  3. Center Console Tear
    By purduecmpe in forum Community Discussion
    Last Post: 11-30-2007, 02:39 PM
  4. Center Console
    By ole69 in forum Other Parts/Misc. Wanted
    Last Post: 05-07-2007, 04:49 PM
  5. Center Console
    By Svashtar in forum Community Discussion
    Last Post: 05-13-2005, 12:04 PM
