Results 1 to 4 of 4
Thread: Nitto NT05R
    Blog Entries
    2
    Question Nitto NT05R
    Has anyone drag raced with the Nitto NT05R?
    I am looking for a Drag Race DOT tire that I can drive to the track.
    I previously used the MT ET Street SS but they no longer make it in 305/45/18.
    My other option is MT Street SS 305/40/18. The section width is +.4" and the OD -1".
    As respects any other options it must be a radial.
    Thank you.
    Aug 2010
    Tennessee
    A buddy of mine had a GT500 swapped mustang, made similar power, maybe a little more than you, and he struggled to make clean passes with that tire. Lots of other variables, track prep, weight, suspension setup, etc. If the tracks around you are known for their radial prep, this tire could work for you. If they tires don't work, you got yourself a spare set of street tires! HAHA
    1999 P71, Chevy 6.0, billet 85mm turbo, 4L80e, 3.73s, E85, etc. 8.91@153
    2003 Mercury Marauder, LS swap in the works
    Jan 2015
    Mishawaka, In
    The nt05r is a good tire, it will hook up fine. How long it last is up to you.
    Apr 2006
    Smyrna, DE
    I use them on Slayer1. They work really well @ Cecil County (1.59 60'). At US-13 2-3 tenths higher 60'.
    3.35 L 4X4
    -AND-
    SLAYER1
  1. Nitto 850
    By Juice in forum Tires & Wheels
    Last Post: 05-01-2011, 05:12 PM
  2. For Sale Two Like-new Nitto 555 295/45/18
    By Rick-n-Miami in forum Marauder-specific Parts for Sale
    Last Post: 08-13-2010, 11:55 AM
  3. Nitto 555
    By gdsqdcr in forum Tires & Wheels
    Last Post: 07-26-2010, 09:06 PM
  4. Nitto or not?
    By Motorhead350 in forum Tires & Wheels
    Last Post: 06-30-2007, 04:02 PM
  5. Nitto NT 555's???
    By Marauderjack in forum Tires & Wheels
    Last Post: 10-20-2005, 04:17 PM
