So going back to the track tonight, last time I went I just left the car in drive and floored it. Is there any advantage to shifting manually?
Turn OD off and let it shift on it's own.
What does turning the OD off do? I'm barely into 3rd when I cross the line.
For some reason the car feels like it shifts harder if I do it manually. When I shift manually it barks the tires on the 1-2 shift, if I leave it in drive it doesn't. Not sure what the difference is. Car has 4.10, Lidio Tune, JLT Cold Air.
shifting manually is very hard on the trans..these trans were not made for that. You'll have more rpms with OD off plus the OD bands are weak and don't hold up to WOT
Leave it in "D". The trans will shift faster and better. Do you have a tune? I'd also do the J-Mod.
If I waited for it to shift automatically I'd be waiting a looonnnggg time!
With that said.. When I was auto I learned the quick way that these ECM's are not as fast to respond as I was to shift, couple that with an older trans and well.. I saw 6,800 twice shifting at 6,200 and my trans was in good shape.
The OD band applies in manual 2. Big No-No
At the strip my best times always came from:
OD : 'Off'
Trans in 'D'
Load converter to about 3,000 rpm.
Let off brake, while simultaneously flooring it on last yellow light.
Trilogy # 192 / T.S. 0012
Well my best was a 14.86 followed by about 3 15.02's and a 15.18 just seems like it should be quicker with the mods I have (4.10, JLT, MSD street fire coils and Lidio Tune). Wondering if I should try a Marty'O tune? My best ever with that combo was 14.68. Tried both 91 and 93 octane tunes and didn't make a difference.
