Is this the correct belt routing for a Vortech on an MM?
If not is there one available?
Thank you.
Thank you.
There are several different belt routings for the Vortech depending on what mounting bracket setup you have and which front cover your running , Vortech has a PDF on their website.
STAY TUNED!!!!!!!!!!
that is how mine is setup with stock timing cover if that makes you feel better
300A Black
Thanks. The pic is from a Vortech PDF for the 2003 Mustang. I will check their website.
The front cover is an MM.
PS Do you still have the Turbo Coyote? Today I was talking to a guy who has been running a rail for a long time. He said 2 Mustangs drove up to the track and ran 8.6!!! The track threw them off because they were in Street Trim. They had turbos.
Thanks Motown and Camel for the help!
