Results 1 to 15 of 22
Thread: FPDM what's needed to Upgrade
    May 2013
    Saudi Arabia
    Smile FPDM what's needed to Upgrade
    Hi everyone it's been a while since I post here and I'm in the final process of installing eaton swap.
    Actually I finished everything (hopfully) and the tunner (marty) said my FPDC % is high and need a dual or bigger one, So I bought another AEM and modified the hat a little bit. But I don't know if the wires need upgrading or not ?
    And most importantly the FPDM upgrade what's need to be changed, Is it the transistor? The Capacitor? The Inductor? Or the Diod? And which spec do I need?
    Please I need your help guys and I already asked Racerx but he's been awhile since his last time available.
    Thanks
    Eaton M112 Supercharger
    Intercooler
    Lower intake plenum
    Coolant Intake Manifold
    TB Intake Plenum
    Throttle Body
    Cobra air intake tube
    Accelerator cable bracket
    Fuel rails
    39lb. injectors
    Cobra heat exchanger
    lower Metco pulley with hub
    Intercooler reservoir
    90mm Lightning MAF
    MAF to filter adapter plate
    Conical air filter
    Custom Gortch Brackets
    Heat Exchanger brackets
    Intercooler pump
    Intercooler pump bracket
    Ribbed idler pulley
    Belt tensioner
    Alternator Pulley
    Fuel Pump
    EGR delete kit
    New accessory belt
    Cooling tube
    IAT sensor
    Nov 2010
    Raleigh, NC
    I'm in the same boat...I wanted one but Noone seems to be modifying them anymore. I can do board solder work so if someone has the spec on what exactly was changed and the parts it'd be simple to modify my own.
    03 300A
    Trilogy #154
    Stainless Works LongTube Headers, Magnaflow High Flow Cats, X-Tube, Rear Cat Delete, Borla Mufflers, 2.5 Mandrel Bent pipes
    Lido tune
    Performance Transmission, 2500 Stall
    Quote Originally Posted by robertmee View Post
    I have a RacerX modded one you can try.
    Nov 2010
    Raleigh, NC
    Appreciate it Jim, but I'd be in the same boat. I want one permanently, whether it fixes my current issue or not.
    03 300A
    Trilogy #154
    Lido tune
    Dec 2009
    http://www.black306.com/?page_id=13
    Upgrade the relay to a 30 amp as well. Keep the 20 amp fuse unless you upgrade the wiring. I didn't and have no issues except for the standard 20 amp relay.
    Looking for the part numbers for the components used in the modification so I can make some of these. Repeated PM's to RacerX have not resulted in any replies.
    Dec 2009
    He posted on the other site a couple times recently. I wrote him there because he owes me a new unit under warranty for well over a year now which he agreed to and he won't respond anymore. I wouldn't say anything but it's been a very long time and I believe he has had time to regroup or whatever he is up to.....
    Quote Originally Posted by tbone View Post
    PM'd him from the other site.
    Dec 2009
    So did I. No response.
    Hiram, Georgia
    I’ve tried reaching him too. No luck.
    I need some modified FPDMs.
    Jim, fill the void!!!!!!
    Anybody remember the guy's name who originally did the mod and sold them on ModularFords forums?
    Been out of the loop for awhile, go this from ModularFords:
    After MJChip (Zone5) closed shop there was someone on Corral that was making the hopped up FPDMs for a while (perhaps still is) although I don't recall who. You might want to just use two FPDMs, one for each pump. That way if one failed you could easily replace it with a stock unit from a local parts store.
    I sure hope mine dosen't fail since it seems nobody makes them anymore.
    Looks like Bill (RacerX) was the one building them. Haven't seen him on here for quite a while, though.
    https://www.mercurymarauder.net/foru...highlight=FPDM
    An alternative might be one of these? Dunno if they'll work on our cars...
    As soon as can identify the components to upgrade I'll start modding them. Probably at the same cost.
    Warson Woods, Missouri
    I called DiAugustino but number is not "working". I also would like an upgraded FPDM.
  1. Modified FPDM vs Stock FPDM
    By NATEHAWK in forum Shop Talk
    Last Post: 10-02-2018, 11:28 AM
  2. Wanted To Buy FPDM needed
    By fastblackmerc in forum Marauder Parts/Misc. Wanted
    Last Post: 04-30-2016, 05:38 AM
  3. HELP NEEDED ON THE BIG 3 UPGRADE
    By jass_BH in forum Shop Talk
    Last Post: 05-28-2014, 09:57 PM
  4. What's needed for Whipple upgrade
    By tdotcv in forum Power Adders
    Last Post: 10-25-2013, 06:20 AM
  5. Driveshaft upgrade? Necessary/needed?
    By FormulaMarauder in forum Community Discussion
    Last Post: 04-14-2011, 08:20 AM
