For the past several years the tire gauges, tried several brands, last less than a year. Currently Green Slime.
Anyone have a gauge, preferably with flex hose, they can recc?
I use one of these from O'reilly Auto Parts. It is a gauge and inflator (air hose connects to it).orly_17-920.jpgA little pricey, but will last a long time.
I use the more expensive ones from any FLAPS.
They seem to last longer.
This is the one I'm using currently. Limited lifetime warranty.
https://shop.advanceautoparts.com/p/...pressure+gauge
Motion Pro 08-0468 0-60 PSI Digital Tire Pressure Gauge
"Want to be really sure about your gauge? Better shops will have a certified reference gauge, or go to a local racetrack where tire support is offered, and your friendly tech should be able to test your gauge."
Joe's Racing. One for normal range, one for low pressure racing range. Not sure if they are 100% accurate, but I like them better than others out there.
Built: 3/16/2004Number 9,879 of 11,052 for Total ProductionNumber 2,040 of 3,213 for 2004 Model YearNumber 663 of 980 Dark Toreador Red ProducedDark Charcoal Interior - CD Changer - Heated Seats - Trunk Oganizer - Moonroof - Rear Deck SpoilerTrilogy S/C kit #224 installed August 2010Detroit Tru-Trac 31 spline with 4.10 gearsetMust - Go - Faster !
