Just replaced my fronts as well, same thing. 30,000 mile rated Nittos and I got barely 25k out of them. The tire centers had that extra 5k in them, but the inside drivers front was wiped out down to the steel showing.
The wear was worse on the drivers side, but shop swears they aligned it to my specs, and since the passenger side was not as bad I figure I just whacked a pothole or something.
Going forward the shop offered to check and verify my alignment for a modest fee every 10k miles, which is a good idea.
