MercuryMarauder.net Forums
Reply
Thread Tools Display Modes
  #1
Old 03-27-2007, 08:47 PM
Breadfan's Avatar
Breadfan Breadfan is offline
Senior Member
Trader: (1)
Breadfan's LED tester
This may be handy for some LED based projects...thought I'd share, and also to prove I do use things out of my boxes of salvaged electrical components!
I had a box of unmarked LED's, most of them were obvious as to what color they were, but I had a pile of clear LED's that were unknown as to what color they were.
Since most LED's run on around 3v, I found some spare parts in my electronics boxes, 2 AA batteries, and made an LED tester.
The batteries are in series routed to an on-off slider switch, which is connected to a salvaged 2-prong computer connector that makes the ideal plug for LED leads.
I found a generic black box and stuffed it in there, cutting holes in the side for the on/off switch and test lead. The AA batteries should last quite awhile testing LEDs.
Sorry for the blurry pics, I should've switched camera to Macro mode...
Oh and most of those clears were unremarkable green's...not more rare blue or white, and not super brights.
__________________
Trilogy #112 (self installed)
12.99@106.2mph (for now)
  #2
Old 03-28-2007, 07:47 AM
Drewstang's Avatar
Drewstang Drewstang is offline
Junior Member
Trader: (1)
My multi-meter has a function were I can test LED's. I think I paid $10 for it at a Flea Market. Not a bad setup you have there either.
__________________
03 Marauder- 300A, Eaton Swapped, current whip
03 Marauder- 300A, 5544 of 7839 in 03, Trilogy #24, SOLD
04 Marauder- 300B, SB with LF interior, 208k miles and still ticking SOLD
  #3
Old 03-28-2007, 08:00 AM
Breadfan's Avatar
Senior Member
Trader: (1)
When I finished i found a slider reheostat switch, I think I'll make a v2.0 with a slider to range from 0v to 6v that way I can test LED's from the small 1.5v to 5v ones.
__________________
  #4
Old 03-28-2007, 08:55 AM
Drewstang's Avatar
Junior Member
Trader: (1)
I'm planning on sitting down and making my own LED emergency lights so I won't have to spend $500-600 when I get back on the Volunteer F.D. I found bulk red LED's with the resistors on ebay for cheap.
__________________
  #5
Old 03-28-2007, 12:28 PM
omarauder's Avatar
omarauder omarauder is offline
Member
Trader: (1)
I would limit the current to the LED with a resistor to prevent burning it out. They're usually happy with 20 milliamps or so. If you know its part number you can usually find the spec sheet online.
Red ones usually require about 1.2 volts, Green about 2.0 volts (I'm guessing on this one), and Blue & White are about 3.0 volts.
regards
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
LED Tailights jgc61sr2002 Shop Talk 5 12-17-2006 04:58 PM
LED Taillights: How? Rider90 Shop Talk 30 01-07-2006 12:46 PM
Torinodan's LED Illumination for cup holders and upper console Donny Carlson Shop Talk 5 03-06-2005 01:11 PM
Overhead console button LED project Donny Carlson Shop Talk 7 04-15-2004 01:43 AM
Powered by: vBulletin
