2004 Silver Birch 300B
Exhaust by Greg
2015 Ford Focus SE Sport FWD
2010 Ford Fusion Sport FWD
I'll take both. Finally saw the hellcat Charger at the Washington Auto show. Smh I need another part-time job
MM Production Sequence Number 406 of 3214 2004 Silver Birch #147 of 993 (Sold 6/5/15)
Other toys:
-2015 Dodge Charger RT Plus, Phantom black pearl, prl/blk lthr, 5.7 MDS Hemi, on order/D1, build date 6/20/15
-1996 Chevy impala SS, very fast car, DCM w/moonroof
-2003 Cadillac Escalade EXT, White Diamond Pearl
-1999 Cadillac Seville STS, Sterling Silver (Sold)
-2010 Dodge Charger Pursuit, Hemi, marked patrol take home
Good GAWD does that HellCat sound awesome!!....
It sounds like the best Hollywood chase scene soundtrack with a wicked blower whine added in!!!
Now if Dodge would just put some real (wide) rubber under the rear fenders.
