Was at work and while in the field, I spotted a black 03 MM with a light beige vinyl top with UM specialty plate. Anyone here?
Righteous Indignation
03 300A
4055 of 7838
4054 of 7093 in Black.
Born 8/23/02
Adopted in 1/15
SOLD
A beige vinyl top on a black MM?
beige vinyl top.no way its anyone here.
Hey DOHC, I finally got around installing that Mach 1 chin spoiler I bought from you awhile back from you, looks great!
03 300A
4055 of 7838
Born 8/23/02
Adopted in 1/15
SOLD
Someone lost a bet.
Name: Bruiser.4 doors - no waiting.2004 Mercury Marauder, BLACK w/Charcoal.Built 09/04/03#261 of 1236 Blacks, 3213 total for 2004(Thanks RoyLPita)Purchased 10/23/2003Adopted 04/25/2004
Hot seats, 6 disc, trunk org, spoiler, avic f90bt & xm, ts-d802 speaks, bumper inserts, pedal and sill covers, 23% tint, 8000k hi/lo hid's & fogs, pro-guard, c.a.i., Xcal2, u.d. pulleys, emp pump, 180 t-stat, autolite 103 plugs, cop connects, coil covers, converter, aluminum pan & cooler, intake spacer, 4.10's, girdle, sway bars, control arms, head cooling kit, shorty headers w/ x pipe, dead pedal, budget big brakes.
"Come with me if you want to live".
