any pics of how low u can sit the azz of these cars?
Want To Buy a Black 03/04 Marauder
Current 1989 Tbird SC blk 5spd For Sale
www.cardomain.com/id/limmer04
Originally Posted by WTBBLKMAR
It still has another 1/2 an inch or so. It can go down even lower but you need to modify the axle bumpers.
is the front lowered in this picture?
Wow I wish i could do that but the car is too long for these evil cenevil ramps they call entrances. Are you using coilovers and modded bag height or springs and modded bag height?
2005 Satin White Pearl Legacy GT
*Stage 2.5* 13.5 @ 96 MPH
2003 Black 300A <---Click for pics.
*Totaled *
The front is at stock height. The rears are larger tires, 255/55/18, and the car was 1/2 inch away from hitting the axle bumpers. I modified the axle bumpers and brought the car up a little more. Stock bags, all you need to do is adjust the height sensor.Originally Posted by MNMarauder
Peek at this...Originally Posted by WTBBLKMAR
http://www.mercurymarauder.net/showc...c=3&userid=392
Front OEM coils cut one full coil, OEM shocks replaced @20K miles, Addco sway bar, poly bushings. 245/45/18 tire.
Rear: Z&M upper and lower control arms, OEM bushings, Addco sway bar, poly bushings, OEM shocks replaced @ 20K miles, air suspension set to factory defaults, modified bump stops, 285/45/18 tires.
Front jack point is 4.50" off the ground, rear jack point is 5.0"
The ride is superb, control is remarkable, the car launches flat, without any loss to body roll, but it will get nervous on older urban pavements.
Was there a how-to yet on modding the height sensors?
*Totaled *
See: http://www.mercurymarauder.net/forum...93&postcount=8Originally Posted by merc6
Sweet! thanks. Turning air suspention off before would be a good idea right?Originally Posted by Rider90
*Totaled *
Turn it off anytime your rear tires are off the ground.Originally Posted by merc6
