Hey guys,
Driver side turn signal blinks fast when engaged. Other side is normal. Guess its a fuse, maybe? Or bulb on its way out? Looks ok.
Thanks
Hey guys,
Thanks
1988 LTD Crown Victoria S
Fast flashing means there is less resistance in the system. .... blinker fluid is low
Bulb is out.
None of the bulbs are out. But I am suspicious that the driver side turn signal bulb might have limited life left since the passenger side went out awhile back.
WLB
#2912 of 7093
Conceived 8/6/2002
Delivered 9/19/2002
Adopted 8/10/2011
Pioneer 6x8 Front
Legacy 600w 6x9 Rears
JL 6.5 SubWoofer
DR Deep Aluminum Trans Pan
Mo's Dyno Tune
Gorilla Nuts - The System
It was still blinking fast on the way to Costco this morning. Slammed the trunk with all my pallets of junk in there and then drove home. Was normal on the way home. Wtf? lol
I have a car with this same issue. Tried new bulbs including higher wattage ones suggested on this forum but the problem persists
Most Notable Posts:
SCT LiveLink - How to Log & Analyze Your Vehicle's Data
SCT LiveLink Gen-II v.1.0 - How to Analyze Your Vehicle's Data
Pro Racer - TP Absolute and TP Relative
Pro Racer - Shift Schedule
Pro Racer - Torque Converter & TC Lockup Schedule
Pro Racer - Tuning For Fuel System Modifications
MARAUDER Stereo Install with MANY Interior Disassy Pics!
BAP Installation with Pics
Vortech & Cobra Motor Install
Whipple & Cobra Motor Install
2016 Show `n Shines
Remove bulb. Smear dielectric grease on terminals. Check female side terminals for corrosion and if they are spread too wide. Adjust with small screwdriver. If any doubt replace them. They are dirt cheap.
If the usual/above-mentined fixes fail to solve the problem, consider the multifunction switch as an expensive last resort; that's what it was on my Crown Vic.
Plate - "EVILMERC"
Started blinking fast again today. I'll start replacing some bulbs to be on the safe side.
One day its blinking fast. The next day its fine. Well, I'll start with replacing the rear tailight bulbs. Found a good video on youtube on the process. But I suppose it could also be the front side marker on that side.
Haven't put new bulbs in yet. Was at Walmart and saw they had the LEDs for the tail lights but had other more important things to buy. Today though, the blinking seemed to go both ways. Even once while I was using them, it blinked normal, then got fast, then normal again in the same use, lol.
Just wondering but i'm experiencing the exact same issue, did you ever get around to replacing the bulb and did that fix that problem?
