For your listening enjoyment and reading pleasure ...
Saw it in person at the Detroit Auto Show...it is a wicked car!
The Carbon Fiber Rims are sick!....
Quick write up about it in the latest Car & Driver magazine. Power numbers are estimates, but sound impressive.
Now this is what someone needs to swap into their MARAUDER. and then go take out some hellcats.
No manual transmission is a big negative to me. Super impressive nonetheless!
Totally agree.
Maybe I should submit a free crate engine request for real world testing? With a manual!
You know, to work out any kinks before these are released into the world and more importantly before the premium priced 2021 standard trans version debuts..
The other problem with the Auto trans is the lame shifter 'dial'....looks like the plastic one in my Fusion Sport. I hate the stupid thing!
I seem to remember my old man having a car in the 60's that you needed to turn the key to ON, then push a button to start it. Can't for the life of me remember what kind of car it was though. Must have been British or Italian. He had Volvo's as well, but push button start seems to exotic for Sweden.
I too think the GT 500 should offer a stick. It should be no more than 5 speeds though, any more is just silly.
First retailed 2003 Marauder
Bought 6 June 2002
#168
That wing though..lol.
In reference to Mr. Man mentioning his memory of a push button start, my earliest memories of being in a car include what I didn't know at the time was a 1951 Chevy 2 door Fleetline. I recall how a key would be put in to the ignition then a seperate button was pressed to energize the starter. I also had an uncle with a Chevy truck of similar vintage but required a pedal on the floor to be pressed for starer operation. Miss those machines.
But if you gonna be exotic, why not a have a pull-start action like a 2 stroke near the hand brake?
