Results 1 to 10 of 10
Thread: NA bottom end build input
    Aug 2018
    Indianapolis
    WAP block 2004
    Heads will have stock cams
    Eagle Steel Crank
    3.554" stroke
    noticed after i bought the crank that it was slightly longer than stock
    Coyote Rods
    Flat Top 10.6 -1 compression
    and http://www.modmaxracing.com/product-p/22025000.htm for pistons
    This is for my first NA build. just wanted to know if the compression increase along with the mild crank difference from stock would hurt anything when running pump fuel.
    I suggest rethinking your plans.
    The heavier rotating assembly and minimal compression increase could actually rob you of power.
    Wisconsin
    My last build was 11.8:1 CR with a 5.0 forged stroker assembly. I went 0.20 overbore. Heads were stock. I did use some nitrous for a while on this.
    I am currently refreshing it and doing new Manley 0.30 over bore pistons and keeping crank and rods I have. My heads will get a refresh as well. With higher compression it can still run 93 octane with the proper tune of course.
    #1724 of 3214 Built 02/13/2004
    2004 Marauder black/moonroof
    SCT flip chip, 4:10's, lowered, big brake kit
    Kenwood KDC-X790 & 4 Kenwood speakers, 10" Sub
    Addco tube sway bars & performance shocks, Metco's
    Zex dry nitrous kit, Full SW Exhaust Kit, PI 3000 Stall
    5.0L Stroker assembly, Self installed!
    E.T. on drag radial tires: 12.270 @ 111.16 & 1.66 60'
    One off custom Hood all steel too.
    SOON TO BE Vortech supercharged
    Ryan Schmuki
    2003 Marauder, black with 4.10s n tune (sold)
    1968 Fairlane 347 built stroker(fast)
    1963 Galaxie 390 auto
    2010 Mercury Milan
    2019 Taurus Limited
    May 2003
    Waterloo, IA
    I don't know. a few more cubes and a pinch more compression will probably eek out a couple more ponies than stock. At a minimum I'd look into better cams.
    Aug 2018
    Indianapolis
    I am open to rod and piston suggestions... its going in an aviator, with aviator intake, I have no problem going for 99 cobra intake cams,
    and I had planned on using a dual throttle body intake from the earlier continental which bolts up.
    I guess its better under partial throttle situations vs the single, the aviator will be the two vehicle for the marauder while being redone as well as some usual driving.
    I suppose building it with the option of later adding a centrifugal supercharger or small turbo is an option at this point. I would like to save some of the budget for the marauder itself.
    I didn't think the weight difference would be very much at all to hurt the power output.
    This will not be a drag racing engine. street driving in a fun suv with some light towing capability I suppose.
    Quote Originally Posted by IndyMerc View Post
    Sounds like you need a blower with 6psi. Much cheaper and easier
    Feb 2017
    Tampa, FL
    A factory set of rods /crank will hold whatever power that engine can make being n/a.
    To make a 5000lb vehicle fun with good towing characteristics, you need torque down low. A 4.6 doesn't make good torque down low without the help of a pd blower.
    IMHO if you MUST be a pump gas NA "fun" tow vehicle WITH A 4.6 starting point Then I would -
    up the compression to ~11-12:1
    Stroke it
    Let it eat
    Honestly with your goals for this truck,- ls swap it, I think you would be happier with the torque
    Junkyard F150 Coyote engine.
    May 2009
    Moreau Island
    Had an Aviator for a while. I'd just open up the exhaust a bit and leave it at that. I think the performance exhaust sound might just fool the brain into thinking your driving a sports truck not a 2 1/2 ton brick. JMO
    Jan 2016
    South NJ
    WAP block 2004
    Eagle Steel Crank
    3.554" stroke
    Coyote Rods
    I have pretty much the same engine, plus 99 cobra cams. I have the stock crank, same rods, .020 over flat tops. Runs 93 octane with zero issues. Have not found out it's true output yet considering I popped a head gasket between the two cylinders, so I've been down on power. Looking to dive into it this weekend.
    Good luck with your setup.
    2003 Marauder 300A
    #2928 of 7838
    Build date: 8/6/02
    Ship date: 5/28/03
    14.33 @ 96.82 with OLD engine
    6R80 swap in progress
    1968 Chevelle
    NA/Pump Gas 10.4 @ 128 mph
    416/4L85E LSA Supercharged build underway
  1. 2.3L Turbo - bottom end Build - for review
    By Loco1234 in forum The Lounge
    Last Post: 04-08-2014, 03:00 AM
  2. Bottom Trim seperating?
    By RichardP in forum Shop Talk
    Last Post: 03-02-2013, 11:42 AM
  3. rebuilding bottom end
    By InfernoHeat2005 in forum Shop Talk
    Last Post: 09-30-2011, 06:09 AM
  4. How do i find my build date, build # , 300a/b ?
    By dj_pizm in forum Community Discussion
    Last Post: 03-03-2010, 05:18 PM
  5. Bottom Site Nav
    By Dan in forum Site Questions and Suggestions
    Last Post: 04-14-2006, 01:18 PM
