Like the title says, looking to go with the badgeless grille on my 2003 MM.
Getting the car painted, so any color grille would work.
TIA
***ETA: I am in Central, Texas. No longer in Upstate, NY***
TIA
2003 MM 300A / Black with Black Charcoal interior
Born: August 28, 2002
Adopted: January 31, 2012 with 33k miles
#4354 of 7093 in Black
#4355 of 7838 Total 2003 models
$400 plus the ride.......
Those were the days.........
DANG THEY'RE CUTE!!!!!!
Smile and Nod
I love THIS bar
03 Merc - your PMs are too full. I can't reply.
Please email me at MyActualScreenName@yahoo.com
Thanks!
Good luck finding a good grille and a donor grille to make one with for less than that, then you still have to build the grille...
#2941 300A
4.10's, carbon clutches
Marty O Tune
Curless Cure
Widened Wheels
Dead Pedal
Eaton Swapped
Bar tender and maker of:
Christmas in a cup
One Legged Lesbian Kickboxer
Cocka Two
Get it while you can. Next year they will be 600
94 Supercharged Miata
92 5.0 Vert
92 5.0 vert summer edition
93 5.0 vert yellow feature car
05 GT vert
81 Fairmont, Vortech, 302, T-56
03 Rubi
If people are getting 400 for bageless grilles I'm going into business. Anyways it's really easy to do. And if your painting it just go get a grand marquis grille from the junk yard of you have to have one. And buy the donor grille from eBay for 30 bucks. And while you could use two part epoxy from home depot and the like, I order West systems handy repair pack enough to do the job and was like 15 bucks.
04 mgm (rauder wannabe)
Jmod, 2900 stall 10inch. Pi shaft and housing with lube mod. 3.73 carbon posi. 70mm tb ported knives edged plate and modded shaft, plenum p and p. Boc tune. And the mods don't stop.
There is a difference between OEM and aftermarket grills but IMHO nut that much that one would have to worry about using it, especially if you are going to make a badge-less grill.
Steven
2004 Marauder Black, loaded
Vortec S/C
4.10s
3500 PI Stall
Kook's headers
476.9 rwhp 385 lbs/tq
Lidio tune
2004 Suburban Dark Charcoal
I prefer aftermarket. They seem to have better flex in the plastics and not so brittle.
I've been looking for one myself....
SEMPER FI From York, Pa
They are really easy to make. I'll admit painting to color match would be some what tricky and pricey but still not impossible
